> Sounds From My 6?
kenshapiro2002
post Feb 5 2026, 10:12 PM
So I’ve had a number of 914s, but my newest is unique to me… a 3.2 six. At the age of 73 after owning over 50 sports cars, I found it rather hilarious that I couldn’t find the dipstick until I talked to ChatGPT. I’ve never had a car until this one where the dipstick was inside the oil fill tube. And I’ve never had a car where checking the oil level was done at idle. So now to my question…when I start her up, she sounds like a volcano with diarrhea for about a minute. I sense that it’s coming from the enormous amount of oil in this puppy. Can someone please explain this phenomena to me?
kenshapiro2002
post Feb 5 2026, 10:36 PM
Never mind… found my answer with AI
post Feb 6 2026, 06:15 AM
Remember, you not only check at idle, the oil must be hot. Like 20 minutes of spirited driving hot, not just 5 minutes of idle in the driveway. So many people overfill 911/914-6 because they don't understand this fact.
brant
post Feb 6 2026, 07:18 AM
Dry sump
Like a real racecar
campbellcj
post Feb 6 2026, 07:50 AM
I can't Re Member
Mine makes a heckuva rushing fluid sound at cold-start as there are big lines running up to the front cooler, and no sound insulation
Ninja
post Feb 6 2026, 10:33 AM
QUOTE(mepstein @ Feb 6 2026, 06:15 AM) *
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
20 minutes of SPIRITED driving hot!!!!!
Dad had a couple of 964s. They had an oil level gauge in them that would SCARE the hell out of you if you didn't know this.
You had to really drive it hard, like traffic ticket hard, far longer than you would think.
Gauge would work, just needed to be up to race temperatures.
Normal wimpy driving I'd guess an hour...
You could easily overfill it two quarts and the gauge would LOOK normal most of the time.
That gauge SHOULD have had a warning. "Gauge is inaccurate until XXX temp is seen on temp gauge".
Most of the time that level gauge made it look like the car had no oil in it!
It will be the same with the dip stick and by the time the dip stick is accurate it's too hot to touch without protection...
- Lo-Fi Version Time is now: 6th February 2026 - 12:22 PM
