> Replacing a Fuel Tank Overflow Hose
nmkimosabe
post Feb 5 2026, 08:19 PM
Does anyone have experience replacing the fuel tank overflow hose on a 914? I bought a reproduction hose from 914 Rubber, but I'm concerned the OEM hose is pre-formed with a right hand turn to go down to the exit drain hole. I can't find any photos of the OEM hose for comparison. I'm hoping to do this without removing the gas tank for improved access on the underside.
Cfletch
post Feb 6 2026, 12:01 AM
please let me know if you can get the hose even installed onto the bung on the tank. I gave up after 30 mins
post Feb 6 2026, 06:09 AM
QUOTE(Cfletch @ Feb 6 2026, 01:01 AM) *
Some WD40 on the bung and hold the end of the hose in boiling water for 30 seconds. Leather gloves.
rudedude
post Feb 6 2026, 07:04 AM
I used the hot air gun and some glycerin as lube. Once on the top I had to use a punch the size of inside tube to get it through the lower hole. Had I known it wasn’t preformed very much I would have just bought pvc tube from the local hardware store
nmkimosabe
post Feb 6 2026, 07:59 AM
Those are all good tips, but did anyone have issues trying to route it under the tank and down the exit hole without removing the tank. I'm concerned the hose will get hung up trying to make a right hand turn for the exit hole since I'm working blind from up top.
- Lo-Fi Version Time is now: 6th February 2026 - 12:22 PM
