| LefthandRev |
Feb 5 2026, 01:30 PM
Member ![]() ![]() Group: Members Posts: 85 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
Hi, all.
I pulled my hand brake to park on a hill. When I pulled it up, the button, shaft, and spring shot out like a rocket. No more hand brake! Started looking closer at it and there doesn't seem to be an easy way to fix or replace it - the brake is riveted to the tub and the fatigued shaft just gave up the ghost. What options do I have here? It's a '74, if that matters. |
| Spoke |
Feb 5 2026, 02:06 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,335 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Everything wrt the e-brake comes off with nuts and bolts. Figure out what part broke and replace it.
A single cable from the handle goes to an equalizer to 2 cables; one to each side. Might be time to inspect and replace any other components which look worn/broken. |
| fiacra |
Feb 5 2026, 11:48 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 680 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
Can't be sure from your description, but this might just be the parking brake button coming unscrewed. If the parking brake button comes unscrewed the rod and spring can come out of the handle. Didn't know that button had to be checked for tightness until that happened to me. Now every now and then I make sure it is still tight. If that's what happened the fix is easy. Put it back together and screw the button back on (unless the threads on the button have stripped). Diagrams are in the PET
| LefthandRev |
Feb 6 2026, 11:25 AM
Can't be sure from your description, but this might just be the parking brake button coming unscrewed. If the parking brake button comes unscrewed the rod and spring can come out of the handle. Didn't know that button had to be checked for tightness until that happened to me. Now every now and then I make sure it is still tight. If that's what happened the fix is easy. Put it back together and screw the button back on (unless the threads on the button have stripped). Diagrams are in the PET my god, man. if i could buy you a beer... Not only was this it, I was able to tighten it down and the lever works perfectly again. for a few years it's just been wonky and wouldn't catch. I checked the cable tension, connections, everything. When it died, I thought, "well, it must have been metal fatigue" and that something broke causing the button and spring to fly out like a rocket. I feel like a dolt. thank you! |
Lo-Fi Version | Time is now: 6th February 2026 - 12:22 PM |
