> Gas tank seam, how close is the weld to the edge?, ...yes, I know this is a bad idea
tomeric914
post Jan 31 2026, 10:00 AM
One Lap of America in a 914!
Yes, I know this is a bad idea, let's get that out of the way.
Looking for a place to mount the clutch reservoir and the seam on the gas tank sure would make a good mounting spot. It appears that the seam weld is closer to the tank itself, but that position could vary depending on how good or bad of a day the operator was having.
Two options using the seam:
1. Drill the seam as far away from the tank as possible using the smallest reasonable fastener diameter that would reliably hold the reservoir in place and survive vibrations, bumps, etc. Literally a 5 minute job. Potential for a fuel leak down the road if I mess up.
2. Design a billet clamp to pinch the seam and bolt the reservoir to the clamp. Not difficult to design. Expensive to machine a one off part. Definitely would not leak.
It could be located somewhere else, but this location is easy to get to and provides for a good route for the reservoir to master cylinder line.
I do see the mounting tab for the evap canaster that could be used if I made a bracket for it. The line routing for that location wasn't as good.
Standing seam clamps for mounting solar panels on metal roofs is another way, but those were a bit too large.
I am open to suggestions!
mlindner
post Jan 31 2026, 01:00 PM
How about just mounting to the brace on the cowl (fare right). When I move my tank to the front you can see where I mounted it to ihe front roll bar.Attached Image
tomeric914
post Jan 31 2026, 02:03 PM
QUOTE(mlindner @ Jan 31 2026, 02:00 PM) *
How about just mounting to the brace on the cowl (fare right). When I move my tank to the front you can see where I mounted it to the front roll bar.
Hmm, the stock tank bulges toward the passenger compartment and really takes up space. I don't think I can make that work. The solution is to get the GT tank! (IMG:style_emoticons/default/biggrin.gif)
Ninja
post Jan 31 2026, 02:16 PM
Tygaboy made a nice mount for both brake and clutch reservoirs in the Ferrari thread.
Check it out for ideas.
He mounted near/on the vertical cowl support brace (center right of your last picture).
If I was going to try to mount that reservoir on the tank seam, I'd make clamps and NOT drill any holes in the tank if I could.
Rob-O
post Jan 31 2026, 04:14 PM
As mentioned above, why not mount it on the cowl brace?
My fear (like everyone else’s) would not only be that the tank leaks but that the tank leaks at the worse possible time and causes other issues.
tomeric914
post Jan 31 2026, 06:14 PM
QUOTE(Rob-O @ Jan 31 2026, 05:14 PM) *
The issue is the line connection off the reservoir. It would hit the gas tank if mounted off the cowl brace. There are other reservoirs that have a bottom connection where the cowl brace would work.
I'll check out what @tygaboy did but I think what he did won't work with this reservoir.
Maybe I'll weld a couple of studs to the gas tank... JUST KIDDING! (IMG:style_emoticons/default/blink.gif)
EDIT: @Ninja I think you mean like this? It's neat and clean but may get damaged if @cupomeat and I do another One Lap of America and have to jam all of our belongings in the car.
I appreciate everyone's input!
Ninja
post Jan 31 2026, 07:00 PM
I think that was on his LS car. I haven't gone through that thread completely.
The ones on the Ferrari car were different, smaller, very tidy.
I'm betting they had bottom exits.
I wish I was better at searching for a specific post.
The hydraulic stuff was quite a while back in that thread and his threads are HUGE!
You tagged him
I'd bet $5 that he will provide (IMG:style_emoticons/default/ninja.gif)
tygaboy
post Jan 31 2026, 07:15 PM
If it were me, I'd get a different reservoir that fits in the available space. I've welded on my fuel tanks but only when they were new. I wouldn't risk welding on one that had been used, but that's just me.
The Ferrari build used the short Tilton version of what I used in the LS car - but I mounted it on a spare cowl support that required upper and lower mounts to be welded to the chassis. Pic below.
Big surprise, but I'm thinking of doing something simpler with individual reservoirs as I think I can make it a bit more tidy.
Again, I'd go with a reservoir that makes it easy to find a spot to mount it.
Ninja
post Jan 31 2026, 07:21 PM
Here's a trick for welding on a gas tank that has been used...
Clean and dry.
Vent a running car into it, shop vac hose usually works.
Let it "fume" for a bit.
This should reduce the oxygen content inside the tank below the threshold for ignition.
bkrantz
post Jan 31 2026, 08:25 PM
How about a bracket that attaches to the brake MC mount?
East coaster
post Feb 1 2026, 08:05 AM
I ended up using the cowl brace. I had modified the brake res bracket to mount my clutch res, but it ended up interfering with the tank. You can see the mod’d brake res bracket in this pic, I didn’t have the energy to remove it even though it’s not used.
Ninja
post Feb 1 2026, 10:43 AM
Here's a thought...
Just T off the supply line from the base of the brake reservoir!
Tons of modern manuals do this anyway.
They have an extra nipple near the base of the master cylinder reservoir, so a clutch hydraulic failure won't take the brakes out.
Due to the long supply line to the master just teeing off (high up) should work fine.
They use the same fluid, heat is not an issue at that end of the systems (usually), and I can't see a critical need to keep the fluids separate.
And you can mess with people!
It's a hydraulic clutch, find the reservoir...
1 Members: sb914
- Lo-Fi Version Time is now: 1st February 2026 - 11:57 AM
