> Need a little assistance, What the heck?
Flyinlow
post Jan 29 2026, 05:29 PM
Flyinlow
74 2.0 project nearing completion testing things out then….hook up battery headlights go up but not on switch on lights close and turn on also-brake lights on when key on… got something wrong
bkrantz
post Jan 29 2026, 07:32 PM
Did you unplug all the leads on the fuse panel during the rebuild?
bkrantz
post Jan 29 2026, 07:34 PM
Check the brake pedal switch. From memory, it has a lever that is pushed to open the circuit when the pedal is at rest.
Spoke
post Jan 29 2026, 11:17 PM
Jerry
QUOTE(Flyinlow @ Jan 29 2026, 06:29 PM) *
This is the circuit for the headlight motors. It sounds like the wires to the headlight motors is reversed likely at the headlight switch.
Flyinlow
post Jan 29 2026, 11:39 PM
Flyinlow
QUOTE(Spoke @ Jan 29 2026, 09:17 PM) *
Anyone have a pic or a layout for that switch?theres a lot of wires on it I do not recall unplugging any
Spoke
post Jan 29 2026, 11:50 PM
Jerry
Here's a thread with info on the headlight switch connections.
Seems like the wires on 30B and 56K are reversed.
1974 Headlight Switch pinout
Spoke
post Jan 30 2026, 12:08 AM
Jerry
A fuzzy schematic showing the connections for the motors at the headlight switch.
Flyinlow
post Jan 30 2026, 10:36 AM
Flyinlow
QUOTE(Spoke @ Jan 29 2026, 10:08 PM) *
Thanks very much…. I will fix this!
ClayPerrine
post Jan 30 2026, 05:55 PM
There is a complete explanation of how the headlights work here:
http://www.914world.com/bbs2/index.php?showtopic=20605
Flyinlow
post Jan 31 2026, 09:43 AM
Flyinlow
QUOTE(ClayPerrine @ Jan 30 2026, 03:55 PM) *
Thanks everyone problem solved (IMG:style_emoticons/default/piratenanner.gif)
- Lo-Fi Version Time is now: 1st February 2026 - 11:56 AM
