| gfg3 |
Jan 27 2026, 12:19 PM
Never Too Old ![]() ![]() Group: Members Posts: 127 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
| TRP |
Jan 27 2026, 12:32 PM
Member ![]() ![]() Group: Members Posts: 188 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
That's the fuel pump, the fuel filter is upstream of that connected to the line that comes from the tank.
Tank --> Fuel Filter --> Fuel Pump --> to the fuel lines to the back of the car. |
| brant |
Jan 27 2026, 12:39 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,131 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
factory fuel pump relocated to front by Porsche on 1975/1976
| gfg3 |
Jan 27 2026, 01:25 PM
OK, thanks folks. That makes a ton of sense. It turns out that what I thought was the fuel pump was actually the dryer cannister for my dealer installed AC. I need to get my glasses fixed.
Now, to get to the fuel filter, do I have to pull out the pump or is there an easier way to get to it? |
| rfinegan |
Jan 27 2026, 02:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,168 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Remove the fuel pump from the access hole, and you will see the factory Square filter mounted on 2 metal strips. In the following pic you can see the metal strips I mention next to my aftermarket Pre fuel pump HERE:
http://www.914world.com/bbs2/index.php?s=&...t&p=3235068 |
| dr914@autoatlanta.com |
Jan 27 2026, 03:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,229 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
aftermarket pump
| Geezer914 |
Jan 27 2026, 05:29 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,204 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I moved my pump and fuel filter near the steering rack. I can just drop the steering rack cover and have easy access. No more worrying about lines kinking.
| worn |
Jan 27 2026, 09:24 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,533 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
Fuel pump in a favorable location, except that I tend to kink hoses anyway.
| gfg3 |
Jan 28 2026, 07:20 AM
Thanks again everyone. If the temperature ever gets above 20 degrees and the snow stops I'll go out into the garage and get to it.
Lo-Fi Version | Time is now: 29th January 2026 - 11:13 AM |
