> What does this switch do on my Motronic Unit?, Not even the po knows
Thunderchief
post Jan 22 2026, 04:23 PM
This switch on the side of the Motonic Unit for my 3.6 swap has 3 positions but not sure why or what it does. Thanks.Attached Image
burton73
post Jan 22 2026, 06:41 PM
Senior member, and old dude
Not stock
Best Bob B
tomeric914
post Jan 22 2026, 07:17 PM
One Lap of America in a 914!
Maybe a way to disable the car as a theft deterrent? Only real way to find out is to pull the cover.
post Jan 23 2026, 08:46 AM
Not stock…. You will need to open it up and see what it’s connected to. Could be the immobilizer or ? Since my Motor was from a tiptronic, I had to cut a wire to tell it my car is a manual.
Thunderchief
post Jan 25 2026, 11:11 AM
Here is is from the inside. Again its a 3 position switch so I'm wondering what the positions are for. Thanks everyone!Attached Image
post Jan 25 2026, 11:42 AM
Flick it - what happens?
3 position irrelevant - only two wires so it’s acting as on/off.
post Jan 25 2026, 11:57 AM
Send a pic to pcarsba@gmail.com
Ingo Schmidt repairs motronic ecu’s and knows them inside out. Super nice guy. I’ve had about 10 ecu repaired by him. Some that steve Wong told me were toast.
Thunderchief
post Jan 25 2026, 11:59 AM
Thanks. It does have an aftermarket chip if that makes a difference
post Jan 26 2026, 10:11 AM
I agree with Tomeric914; likely a kill switch. (IMG:style_emoticons/default/beerchug.gif)
ClayPerrine
post Jan 26 2026, 02:03 PM
I know the 964 had a jumper to change fuel map when you are forced to run cheap gas. That may be wired up to change the fuel map.
- Lo-Fi Version Time is now: 13th March 2026 - 03:51 AM
