| Geezer914 |
Jan 20 2026, 07:11 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,242 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I am trying to figure out how much additional oil is needed when adding an external oil cooler and a Billet aluminum Tuna can? 10 ozs. sound right? 3.7 qts. + tuna can equals 4 qts. of oil.
Setrab oil cooler .53 qts. or 17.2 oz. 110" of 1/2" hose 12 oz. engine oil + Tuna can 4qts.? 128 oz. total 157 oz. or 4 qts. + 29 ozs. So I would need 4 qts. plus an additional 29 ozs. of oil??? |
| Cairo94507 |
Jan 20 2026, 09:09 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,590 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
That sure seems like you are in the ballpark to fire it up, drive it, check it after the thermostat opens and know oil is flowing as planned. (IMG:style_emoticons/default/beerchug.gif)
| Chad911sc |
Jan 23 2026, 08:07 AM
Member ![]() ![]() Group: Members Posts: 274 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
I have the exact same set up as you….
I wondered the same thing. I was running my engine during the break in period and the tuning, before I had to take it all back apart, with 4.3 quarts. Never could figure out how much of my oil was draining back from the cooling system into the case after shutdown. I always had about 3mm over the full line after cool down. |
| brant |
Jan 23 2026, 09:08 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,158 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Is it a front cooler or rear?
My 4 has a front earls cooler with tuna can and is 6-7 quarts |
| Chad911sc |
Jan 23 2026, 12:57 PM
It’s a rear mount under the trunk floor.
Attached thumbnail(s) |
| Geezer914 |
Jan 23 2026, 04:51 PM
Rear mount cooler under the trunk floor. Added the volume of the cooler and hoses and came up with 29 ozs. The tuna can brings the normal capacity to 4 quarts. So 4 quarts plus 29 ozs.
| Chad911sc |
Jan 25 2026, 05:29 PM
How does it look on your dip stick after the engine cools? Is it higher than full mark? Or do you have a one way stop valve in the cooling system? I guess I am getting some drain back due to it being a few mm above full when cool.
@geezer914 |
| Geezer914 |
Jan 26 2026, 06:41 AM
I have not started the car as yet, 17° here with a foot of snow!
Lo-Fi Version | Time is now: 13th March 2026 - 03:51 AM |
