> Door Hinge Pins, Door Hinge Pins
nmkimosabe
post Jan 18 2026, 05:28 PM
Hi ---this is my first post on the forumn. Can someone please confirm that the location of my door hinge pins is correct as there is a small gap between the pin head and the hinge. Thank you.Attached Image Attached Image
post Jan 18 2026, 05:48 PM
That seems to be normal. As long as they hold the door in place, you’re good.
post Jan 18 2026, 06:18 PM
Gap is factory so you can fit the pulling tool for removal.
post Jan 18 2026, 07:08 PM
Looks right, how is the rest of this example?
nmkimosabe
post Jan 18 2026, 07:14 PM
Thanks to all for the quick responses. I'll be posting again I'm sure as this is my first 914.
post Jan 19 2026, 01:53 AM
yeah mine are still factory installed.
bit of a gap.
its cool. (IMG:style_emoticons/default/beerchug.gif)
Jamie
post Jan 19 2026, 08:11 AM
QUOTE(nmkimosabe @ Jan 18 2026, 03:28 PM) *
I've wondered why these pins are installed upside down in defiance of gravity? Since there is no other retainer other than friction fit seems they would eventually just fall out, not usual German engineering. (IMG:style_emoticons/default/blink.gif) I've never attempted to remove one, are they hammered into place?
rudedude
post Jan 19 2026, 08:14 AM
What you can’t see are the serrations on the shaft that lock them in position. They are difficult to remove even with the factory tool.
- Lo-Fi Version Time is now: 19th January 2026 - 09:53 AM
