> light switch, wrong switch
fiberglass1inc
post Jan 14 2026, 03:42 PM
Hello 914 brothers and sisters! I have a 73 914 with a 75 engine. Had some issues with the light switch which I believe is a 75 switch (12 pin, the 73 switch is 9 pin). When the turn signals are used they don't work and the low oil pressure light comes on (pressure is not low). This is recent, always worked before. Has anybody seen anything like this? Thank you in advance.
post Jan 14 2026, 04:17 PM
Headlight switch? The 73 switch should be a 10-pin, the 75 switch is an 11-pin.
They are functionally identical, doubt the headlight switch is the cause of the issue you are experiencing.
post Jan 14 2026, 04:47 PM
Grounding issue?
fiberglass1inc
post Jan 15 2026, 09:38 AM
QUOTE(JeffBowlsby @ Jan 14 2026, 05:17 PM) *
Thank you for that, thought it was 9 and 12 but been a while since i looked at it. Does actually sound like a ground issue.
post Jan 15 2026, 09:55 AM
The grinding may be a defective switch (inspect it further...the rheostat within it may be bad), but the switch is not related to low oil pressure. Also, look at your turn signal switch, it may be going bad.
- Lo-Fi Version Time is now: 15th January 2026 - 09:10 PM
