> Ignition Switch Quality Check, Is this usable? Or send back?
Nogoodwithusernames
post Jan 12 2026, 11:24 AM
Wanted to start a separate thread from the troubleshooting thread I hijacked the other day. I ordered 3x ignition switches from PMB knowing that quality of these may not be top notch, today they showed up and all three have the center spade crooked, and the plastic housing isn't seated fully. All three identical.
Will they work? Or does this warrant sending back? I hate to make PMB deal with this sort of thing that isn't even their product.
URO parts for those curious.
StratPlayer
post Jan 12 2026, 12:38 PM
StratPlayer
I get mine from a vw vendor
post Jan 12 2026, 06:54 PM
I don't know of a good aftermarket supplier. I only use Porsche. Even they break at the spring end hole.
There is already a thread about ignition switches
Nogoodwithusernames
post Apr 28 2026, 09:40 AM
Well I finally got around to replacing the ignition switch this past weekend. While it technically works, I don't think it was the right part even though they checked for the year I have before shipping. I had to remove the "flange" at the bottom of the replacement and had to bend the crooked male prong. Other than that everything went smoothly.
And now the 914 starts up with no wiggling and jostling the key anymore, so I'll call it a win!
post Apr 28 2026, 09:52 AM
I got the same switch last year and sat on it till this spring. I ground off all that unnecessary stuff as well. Seems to work fine. Mine was from 914rubber.
TheCabinetmaker
post Apr 28 2026, 10:15 AM
I drive my car everyday
That switch is for 75\76. Get the proper one and you won't have to modify it
Root_Werks
post Apr 28 2026, 11:05 AM
Village Idiot
QUOTE(TheCabinetmaker @ Apr 28 2026, 09:15 AM) *
Good thread on it:
http://www.914world.com/bbs2/index.php?showtopic=374169
1 Members: 914sgofast2
- Lo-Fi Version Time is now: 28th April 2026 - 04:40 PM
