> Curse Those Rear Lug-Centric Wheels, Why did Porche decide on them?
Osnabruck914
post Jan 9 2026, 04:15 PM
Having been doing a lot of suspension work on my 914 of late, has necessitated unmounting and mounting my wheels repeatedly. Putting the hub-centric fronts back on is a piece of cake, but those damn lug-centric rears are always a pain to line up the lug nut holes, especially in the bright Florida sunshine. Is there a reason Porsche chose lug-centric for the rears? If there is, then I can more readily accept the aggravation they cause. Is there a hack to make it easier? Someone please educate me...Thanks.
Osnabruck914
post Jan 9 2026, 04:36 PM
Osnabruck914
post Jan 9 2026, 04:49 PM
Thanks, Superhawk. I was not aware such a kit existed. Decent price, too. Would still like to know the reasoning behind lug-centric.
Osnabruck914
Craigers17
post Jan 9 2026, 04:53 PM
I haven't tried them, but Tangerine offers a Hub Centering Ring that might help a bit. Here:
https://tangerineracing.com/shop/ols/produc...centering-rings
Or you could add studs.....that would make it a bit easier.
Ninja
post Jan 9 2026, 05:26 PM
Both "Hub-centric" and studs are the recipe in my book.
My current set up uses 14-6 rotors drilled for 5 lug (PMBs stuff) with studs.
This set up is still lug centric in the back.
A member on here CNCd a set of hub-centic adaptors.
I bought extras...
The reason they went lug centric was associated with cost IMO.
It very quickly became apparent that a hub centric mounting was significantly stronger and easier to achieve wheel centering during installation.
In accidents the wheels stayed on the cars better with hub centric mounting.
I do not believe I've seen lug centric mounting on ANYTHING built in the last 3 decades...
rfinegan
post Jan 9 2026, 05:40 PM
Depending on you wheels CFR has some hub centric adapters. I have a set and work very well...
- Lo-Fi Version Time is now: 11th January 2026 - 12:34 AM
