| robkammer |
Jan 9 2026, 01:57 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Happy New Year Teeners! Sorting out some small issues on our BB, and I'm hoping that someone can share some testing specs for a thermotine sending unit. I'm assuming it meters a 12volt signal from the control unit to the AAR. But as assumptions go, that's where I am.
Also, does anyone know if these are still available? Or does anyone have one in good working order they'd like to sell? Rob ![]() |
| ejm |
Jan 9 2026, 02:39 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,714 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Your picture is a decel valve
Jan 9 2026, 02:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,616 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The thermoswitch controls the cold start injector. Has nothing to do with the AAR.
The thermoswitch and cold start injector don’t even come into play unless vehicle and ambient temperatures are around 32F and below. Review the Anders overview of d-jet operation and components. https://pbanders.synology.me/914/djetfund.htm Thermoswitch can be tested by placing in the freezer and then monitoring continuity with a DMM as it warms back to room temperature. It should be closed when it first comes out and then should go open as it warms towards ambient. |
| JamesM |
Jan 10 2026, 01:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,176 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Happy New Year Teeners! Sorting out some small issues on our BB, and I'm hoping that someone can share some testing specs for a thermotine sending unit. I'm assuming it meters a 12volt signal from the control unit to the AAR. But as assumptions go, that's where I am. Also, does anyone know if these are still available? Or does anyone have one in good working order they'd like to sell? Rob ![]() The thermotime switch is just that, a switch. On/off. Unless it is broken it ONLY comes into play at VERY cold temperatures (below freezing) and while cranking. Has no impact on how your 914 runs (though a leaky cold start injector will) it only impacts sub freezing starting performance. For most people these days you can eliminate the cold start injector completely with no impact on your 914 experience as most people dont start their 914s in sub freezing weather anymore. The device in your hand is the decell valve, though that one appears to have been modified/plugged. Also can operate the car without that though some believe running without it may overstress the MPS diaphragm. |
| pbanders |
Jan 10 2026, 08:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 963 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
Happy New Year Teeners! Sorting out some small issues on our BB, and I'm hoping that someone can share some testing specs for a thermotine sending unit. I'm assuming it meters a 12volt signal from the control unit to the AAR. But as assumptions go, that's where I am. Also, does anyone know if these are still available? Or does anyone have one in good working order they'd like to sell? Rob ![]() They're NLA. Ebay or classified here is your best bet. Test yours to make sure it's not working. Take the tape off that side port and try to blow through it. Do the same on the other two ports. If you can on any of the three, it's no good. |
Lo-Fi Version | Time is now: 11th January 2026 - 12:35 AM |
