| robkammer |
Jan 9 2026, 01:38 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
All: Started this morning to get the BB's few quirks figured out while it's still winter. Last year the car ran great, but it had trouble staying running for the first 5 miles or so. Cold start no problems, let it sit and idle for 5 minutes, ls no problem. Once underway, as soon as I let off the pedal, it would want to stall. I was able to get through it by using the hand brake, but that's a pain.
I know I have a bad vacuum valve that is supposed to shut the throttle body down on decel, but I've just plugged it and left it place. If it's not plugged, the open vacuum takes the idle way too high. It's been like that for two years, but not for long if I can find a new one. The AAR is working but I'm not certain about the Thermotine sender. I'm sure Jeff B or someone smarter than me has the specs to bench test one. If anyone has suggestions on what might be the problem here, I'm open to all suggestions. Cheers! Rob Attached thumbnail(s) |
| brant |
Jan 9 2026, 03:33 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,120 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Test your CHT.
It could be failing when fully warm ? |
| FlacaProductions |
Jan 9 2026, 03:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,124 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Fuel hose kink that after it gets going, collapses and restricts flow?
Jan 9 2026, 06:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,442 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
This sounds like a bad aar
| rjames |
Jan 9 2026, 08:46 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,420 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Jan 10 2026, 05:58 AM
If it's gone, but it can be a slow death with such an analog device. Just might not be opening all the way when cold but still closes eventually.
Jan 10 2026, 05:59 AM
And I have no idea what a "thermotine sender" is.
| robkammer |
Jan 10 2026, 07:22 AM
Thanks for the replies. The AAR is functioning well. The sending unit is mounted on the intake manifold and connects to the AAR, and to the wiring harness that goes to the FI control box. Thermotine may not be the right name, but it's feeding the AAR.
Jan 10 2026, 07:36 AM
Perhaps you have something miswired? The AAR is fed only by a switched 12v wire. Perhaps the temperature sensor mounted near it (just towards the passenger side a few inches) has been confused with the AAR system? That temp sensor mounts to the surface of the block towards the front of the plenum and does feed into the ECU. Although it has nothing to do with the AAR.
| bdstone914 |
Jan 10 2026, 07:46 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,231 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@emerygt350
' date='Jan 10 2026, 05:59 AM' post='3240252'] And I have no idea what a "thermotine sender" is. [/quote] Thermo time sensor that sends a signal to the cold start injector. Only affect cold start unless it it shorted and sends constant signal and extra fuel is continuously injected. |
| bdstone914 |
Jan 10 2026, 07:47 AM
Duplicate
| sechszylinder |
Jan 10 2026, 08:47 AM
Member ![]() ![]() Group: Members Posts: 270 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None
It is difficult to determine from a distance because it can have several causes, all of which have to be examined.
but maybe you should have a look at the troubleshooting table on this page if you‘re not already aware of this site : https://members.rennlist.com/pbanders/DJetParts.htm br Benno (IMG:style_emoticons/default/smilie_flagge6.gif) |
| robkammer |
Jan 10 2026, 10:38 AM
Thanks fellas, all good info. My mistake, Thermo time switch, duh. I've been looking through Brads Djet manual. I am mistaken that the TT switch feed the AAR info. I'll check my diagrams when I get to the shop. Does the CHT sensor control the AAR?
One thing that seems certain, most of these parts are going to be hard to find if needed. |
| sechszylinder |
Jan 10 2026, 11:01 AM
Does the CHT sensor control the AAR? no definitely not. The CHT is directly connected to the ECU. Sometimes there is a series resistor connected in between the CHT and the ECU, but the AAR get its power from the relay plate, which is on, when you turn on the ignition. br Benno |
| robkammer |
Jan 10 2026, 02:37 PM
Thanks Benno! That makes sense, hot all the time regardless of temperature, I think. I've spent some time reviewing the wiring diagrams in the Bentley and others, nothing gives a clear picture of the EFI routing or of the various sensors and devices. Right now I'm debating with myself about pulling the motor, just because I haven't yet and I know it needs some love, and that would make it a lot easier to clean up and organize the intake area. I had planned on a full suspension refresh on on of our other cars, maybe I can get that done before driving season and then put the BB on the rack.
In the meantime, I'll be reading through Brad Anders excellent collection of D-Jet info, It sure can't hurt. Rob |
| JeffBowlsby |
Jan 10 2026, 04:34 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,159 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
The TTS is a temperature dependent sensor, it only provides ground to the AAR, completing its circuit to the AAR based on the ambient air temp just above the engine case. Super simple, just the we like it.
Brad Anders D-Jet pages have a new link, actually its now hosted directly on his personal server: https://pbanders.synology.me/914/ The previous site may remain accessible on rennlist for awhile, they don't keep them updated. Use the new link which has the most up to date information. |
| pbanders |
Jan 10 2026, 08:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 963 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
It is difficult to determine from a distance because it can have several causes, all of which have to be examined. but maybe you should have a look at the troubleshooting table on this page if you‘re not already aware of this site : https://members.rennlist.com/pbanders/DJetParts.htm br Benno (IMG:style_emoticons/default/smilie_flagge6.gif) Updated URL: https://pbanders.synology.me/914 Just saw Jeff already posted it... |
Jan 10 2026, 08:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,616 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The TTS is a temperature dependent sensor, it only provides ground to the AAR, completing its circuit to the AAR based on the ambient air temp just above the engine case. Super simple, just the we like it. @JeffBowlsby Think you meant cold start valve (injector)? The thermoswitch has nothing to do with the AAR. |
| JeffBowlsby |
Jan 10 2026, 08:56 PM
Of course… (IMG:style_emoticons/default/smilie_flagge6.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/thumb3d.gif) what was I thinking. [hand slapping forehead…]. TS and TTS on later cars grounds the CSV.
(IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 11th January 2026 - 12:34 AM |
