> Stock Blaupunkt speaker photos
s13u74cr4
post Dec 28 2025, 11:57 AM
These were in my 73. Thought the room might like to see a set. Still work!
I thought they were supposed to be 4 OHM at the time.
windforfun
post Dec 28 2025, 12:04 PM
Hmm... Coaxials?
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif)
Osnabruck914
post Dec 28 2025, 12:33 PM
As far as I remember, 8 ohm was pretty standard for automotive speakers back then.
Osnabruck914
DennisV
post Dec 28 2025, 12:57 PM
QUOTE(s13u74cr4 @ Dec 28 2025, 09:57 AM) *
I did some brief research on this. There is some evidence to suggest the early 70s radios are meant to have 8 ohm speakers. Later cars 4 ohms.
Thanks to Radiomuseum.org, I found a manual for our specific model 1970 Frankfurt US 7639670. It it indicated 5,8 ohm. The Zenith speakers in the car measure ~6 Ohm.
fixer34
post Dec 28 2025, 02:39 PM
Here is one of mine, '70 factory -6. Doesn't appear to have ohms noted.
Although I have no way of knowing if the radio/speaker was factory or dealer installed. Nothing listed on CoA.
chmillman
post Dec 28 2025, 04:03 PM
The ones I took out of my 74 2.0 look similar to the above - someone here said they are more or less OEM. No name...
s13u74cr4
post Dec 28 2025, 05:38 PM
These look really close to mine. Do they work? Gonna swap in some new somethings for sure.
Your +/- are the same terminal size no? Mine are not.
QUOTE(fixer34 @ Dec 28 2025, 12:39 PM) *
s13u74cr4
post Dec 28 2025, 05:40 PM
These look larger. They fit in the pods?
QUOTE(chmillman @ Dec 28 2025, 02:03 PM) *
fixer34
post Dec 28 2025, 09:14 PM
QUOTE(s13u74cr4 @ Dec 28 2025, 05:38 PM) *
I don't have the radio on very much, but both speakers work. Not sure about + or - terminals; they are the same size and been a long time since I traced the wires back to the actual radio,
chmillman
post Dec 29 2025, 01:32 AM
QUOTE(s13u74cr4 @ Dec 29 2025, 12:40 AM) *
Yes, they do. Did - I took them out, in their place is a pair of modern 4x6’s with custom adapters to the OEM housings.
s13u74cr4
post Dec 29 2025, 12:41 PM
These custom adapters, make them or buy them? The originals are an odd size. Photo?
QUOTE(chmillman @ Dec 28 2025, 11:32 PM) *
chmillman
post Dec 29 2025, 03:03 PM
QUOTE(s13u74cr4 @ Dec 29 2025, 07:41 PM) *
Made them. Story here:
http://www.914world.com/bbs2/index.php?sho...=371580&hl=
Starting at post #4
- Lo-Fi Version Time is now: 30th December 2025 - 01:21 AM
