| brant |
Dec 27 2025, 05:40 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,116 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
more cleaning out of my shed full of 914 parts. a big batch
prices do not include shipping which i can send for actual cost Bosch blue coil used 35+ shipping PENDING Attached thumbnail(s) |
| brant |
Dec 27 2025, 05:44 PM
a single 1.7 injector that was sent out/rebuilt... unfortunately i cant find the spec sheet
40$ + shipping Attached thumbnail(s) |
| brant |
Dec 27 2025, 06:20 PM
1975 l-jet injectors
cores, used to run 10 years ago, stored dry 100+shipping Attached thumbnail(s) |
| brant |
Dec 27 2025, 06:25 PM
air box mount for L-jet
15$ plus shipping in good condition SALE PENDING Attached thumbnail(s) |
| brant |
Dec 28 2025, 11:22 AM
901 gear ratio
this M ratio is often flipped for a lower 3rd gear, autox, etc 125$ + shipping PENDING Attached thumbnail(s) |
| brant |
Dec 28 2025, 11:26 AM
X 901 gears set
also for lower gearing this one in 5th, makes for a useable 5th at events 150$ plus shipping PENDING Attached thumbnail(s) |
| brant |
Dec 28 2025, 11:30 AM
both brackets for mounting the ECU on a D-jet car
50$ + shipping Attached thumbnail(s) |
| brant |
Dec 28 2025, 11:45 AM
1.7 distributor with trigger points
was used as a travel spare for emergencies very low test miles on cap/rotor/points works well the vacuum canister diaphram holds vacuum on the port pointing outwards, not on the port pointing in 50$ plus shipping Attached thumbnail(s) |
| brant |
and
| brant |
Dec 28 2025, 11:57 AM
core 74 2.0 throttle body
not complete send this in for a rebuild while keeping your car running 10$ + shipping Attached thumbnail(s) |
| brant |
Dec 28 2025, 12:04 PM
rebuilt alternator
had a few rebuilt at once used a great old time shop in Berkley, who was bosche certified (i have another one they did in my driver) includes the harness, and brand new rebuilt 250$ + shipping PENDING Attached thumbnail(s) |
| brant |
Dec 28 2025, 01:48 PM
L jet throttle body
no TPS very good core no wear edges from butterfly 50$ + shipping Attached thumbnail(s) |
| brant |
Dec 28 2025, 01:55 PM
oil pump plate from cludes buggies (cb)
this is for a conversion to a full flow oil set up 10$ + shipping Attached thumbnail(s) |
| brant |
Dec 28 2025, 01:57 PM
seat belt cover
free Attached thumbnail(s) |
| brant |
Dec 28 2025, 02:17 PM
track exhaust made to fit the 2.0 bursche muffler
some of the bursche's have a removeable muffler at the flange just upstream it was an option this bolts there, maintains the cross-over of the system center outlet.. 3 bolts i used to drive to the track and bolt this on i have a spare flange if your bursche doesnt 20$ + shipping Attached thumbnail(s) |
| brant |
Dec 28 2025, 02:28 PM
Ljet distributor
no play both vacuum ports work on the canister i boughts this years ago due to a thread about the advance curve being good for carbs... never put it to the test 100$ + shipping Attached thumbnail(s) |
Lo-Fi Version | Time is now: 30th December 2025 - 01:23 AM |
