| Blue Lightning |
Dec 7 2025, 04:47 PM
Member ![]() ![]() Group: Members Posts: 69 Joined: 7-December 23 From: Atlanta, GA, USA Member No.: 27,780 Region Association: South East States |
1976 2.0. Putting engine back in after a 2056-dectomy, but it has been out too long and as usual I didn't take enough pictures of all the important connections.
There are many threads on wiring for the starter. However, I have one additional wire that I don't see in any of those threads, but I marked as going to the starter solenoid. Wire in my hand: ![]() Way off to right: ![]() Out of focus in center: The wire in question is red and has a spade terminal on the end. It is not the cable that runs from the alternator. My best guess as of today is that is leads up to the firewall and goes through here: Thoughts? Car has air conditioning, so is this part of that? |
Dec 7 2025, 06:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 614 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Your car looks different because it's been modified.
Some people do this to address "hot start" problems. Some don't make this modification because they believe the problem is actually caused by corroded wires or the amperage draw from a Bosch starter (replace with a Hi-Torque or other starter that doesn't draw too many amps). Your call. Further discussion and a schematic can be found here: http://www.914world.com/bbs2/lofiversion/i...t308904-50.html |
| Blue Lightning |
Dec 7 2025, 09:33 PM
Your car looks different because it's been modified. Some people do this to address "hot start" problems. Some don't make this modification because they believe the problem is actually caused by corroded wires or the amperage draw from a Bosch starter (replace with a Hi-Torque or other starter that doesn't draw too many amps). Your call. Further discussion and a schematic can be found here: http://www.914world.com/bbs2/lofiversion/i...t308904-50.html Agreed my car has the "hot start" mod. But I still have the same question: what is the red wire with the spade terminal for that I'm holding in my hand? This doesn't appear to be part of the mod -- it comes through the engine tin, is about the correct length to connect to the starter solenoid, and appears to run back through the firewall. ![]() |
| Rob-O |
Dec 8 2025, 09:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,298 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
Follow it through the engine tin. Where does it go (or connect) in the engine bay?
| Blue Lightning |
Dec 8 2025, 01:46 PM
| Dlee6205 |
Dec 8 2025, 02:05 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
Agreed my car has the "hot start" mod. But I still have the same question: what is the red wire with the spade terminal for that I'm holding in my hand? This doesn't appear to be part of the mod -- it comes through the engine tin, is about the correct length to connect to the starter solenoid, and appears to run back through the firewall. ![]() The answer to your question is we don't know... its custom. Tracing this wire through the tunnel to see where it terminates will likely help answer your question. Does your starter circuit currently work as-is? It could be a ground for the hot start solenoid but I have my doubts. Are you sure that particular wire goes to the starter area and not somewhere else? Do you have any other custom additions such as an oil pressure gauge? |
| Spoke |
Dec 8 2025, 02:42 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,279 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
1976 2.0. Putting engine back in after a 2056-dectomy, but it has been out too long and as usual I didn't take enough pictures of all the important connections. There are many threads on wiring for the starter. However, I have one additional wire that I don't see in any of those threads, but I marked as going to the starter solenoid. Wire in my hand: ![]() Way off to right: ![]() Out of focus in center: The wire in question is red and has a spade terminal on the end. It is not the cable that runs from the alternator. My best guess as of today is that is leads up to the firewall and goes through here: Thoughts? Car has air conditioning, so is this part of that? Where does that black wire end up? What is it attached to? It almost looks like some kind of power wire. As others have said, you have the 'Ford Relay' modification. To really understand each wire you'd have to make a simple schematic drawing yourself then others can help you wire it. Follow each wire to where it goes and document it. You're is a custom configuration from OEM. |
| Dlee6205 |
Dec 8 2025, 03:09 PM
I just saw where you said your car has AC... its entirely possible to be power for that too.
Lo-Fi Version | Time is now: 8th December 2025 - 03:33 PM |
