| beltwerks |
Dec 6 2025, 04:15 PM
Newbie ![]() Group: Members Posts: 17 Joined: 14-January 19 From: UK Member No.: 22,800 Region Association: None |
As a newcomer to the world of the 914 i will be asking some rookie questions. (IMG:style_emoticons/default/biggrin.gif)
I'm about to remove the 1.7 engine from my car as i intend to install a 6 engine once restored. Is there anything i need to keep from this engine before i offer it for sale .? Wiring, clutch, flywheel etc. Thanks in advance Dave |
Dec 6 2025, 04:25 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,280 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I cant think of anything from the engine that gets used for the conversion.
Dec 6 2025, 04:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,355 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
A reasonably large bank account to start Dr 914, Auto Atlanta has a booklet describing most of whats required, Pelican also has something It's a process, but keep the questions coming. We will get you through |
| beltwerks |
Dec 6 2025, 05:14 PM
Thanks for the replies, much appreciated. I will keep on reading and try to learn. Now, if anyone wants any seatbelt advice i'm your man.
| Ninja |
Dec 6 2025, 06:33 PM
Newbie ![]() Group: Members Posts: 41 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Does the 1.7 run?
I might leave it in to debug the chassis. A Porsche 6 conversion is complicated and expensive. There are more threads regarding these types of conversion here than anywhere else. You've come to the right place... Spend some time going through the threads! |
| sixaddict |
Dec 6 2025, 07:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,007 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
There are many people on here that are far more knowledgeable than I and you have a great start from some of the best. I have done a couple and have a few suggestions.
First is a lot of people have their preferences……motor mounts for example….. You have several choices so do your homework. You also have choices when made early can be easy. There are things people don’t do…..like removal of -4 engine mounts to make it cleaner. Depending on your use street/track or both you have choices on brakes and cooling that are best made early in your build. It’s a matter of how deep you want to go…….Welcome and good luck with your build. Just my 2 cents. |
Lo-Fi Version | Time is now: 6th December 2025 - 07:22 PM |
