| Literati914 |
Dec 5 2025, 09:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
This Happened (for several miles on the N. TX toll road):
Attached thumbnail(s) |
| Literati914 |
Dec 5 2025, 09:03 AM
Causing this to happen (I’d just pulled the windshield because of the stupid trim clips at the center top (IMG:style_emoticons/default/headbang.gif) )
| Cairo94507 |
Dec 5 2025, 09:12 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,511 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
This is the 2nd post I have seen regarding window trim popping off at speed. What is causing this? I have had my car at 130 for a good bit and no issues so far. (IMG:style_emoticons/default/confused24.gif)
| friethmiller |
Dec 5 2025, 09:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,093 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
If this turns out to be the trim clips, I'd be laying down the $$$s for the Porsche OEM clips.
| brant |
Dec 5 2025, 10:20 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,106 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I also would guess that the trim clips were not replaced (no windshield shop would stock these). Or it wasn’t clipped all the way if it was replaced
Believe the factory calls these clips one time use Most windshield shops use glue instead of and just are not familiar with using clips |
| Literati914 |
Dec 5 2025, 11:01 AM
When I originally installed the windshield - apparently two clips at the top center broke for whatever reason (IMG:style_emoticons/default/confused24.gif) (aftermarket from a supplier we all use ).. I pulled the windshield about a month ago to replace the broken clips. I ended up replacing them all because I had an extra set of the aftermarket ones as I'd bought two sets for two cars before I knew these suck (most felt fine to use again tho, TBH), but yea will buy the Porsche ones from now on.
I know they need to be pushed in firmly, these were.. but you can see in my picture that, that particular clip has backed out a bit towards the glass. IF THE LITTLE CHEAP PEG HAS NOT BROKEN, I can probably push it back in and 'brace' it in place w/ more butyl. Fingers crossed that it works - cause slipping one in is out of the question, the whole glass has to come out. |
| Root_Werks |
Dec 5 2025, 11:53 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,862 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Replaced my windshield about 3 years ago and replaced 2-3 broken clips with aftermarket clips. Haven't had trim pop off yet and agree, it's a bit tricky to get the trim to clip into the clips.
| volksaddict |
Dec 5 2025, 02:31 PM
Newbie ![]() Group: Members Posts: 36 Joined: 29-January 11 From: southwest Member No.: 12,645 Region Association: Southwest Region |
I thought the second pic would be red lights behind you
Dec 5 2025, 02:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,354 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
This is the 2nd post I have seen regarding window trim popping off at speed. What is causing this? I have had my car at 130 for a good bit and no issues so far. (IMG:style_emoticons/default/confused24.gif) How grounded is she at speed? |
| porscheteck914 |
Dec 5 2025, 04:09 PM
Member ![]() ![]() Group: Members Posts: 53 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States |
Lets see you were going 90 MPH in 3rd gear thru a toll road . Oh its the new speed restrictor lasers the state has set up to do any car going that fast . They dismantle your car piece by piece starting with the windshield . That not slow you down they throw out the spike chains.
Lo-Fi Version | Time is now: 5th December 2025 - 07:01 PM |
