| Mitox |
Nov 28 2025, 03:25 PM
Member ![]() ![]() Group: Members Posts: 459 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States
This kit from JBugs looks like it would work on the 914. Maybe?
The sale Price looks good also. https://www.jbugs.com/product/16-2236.html VW 930 Axle Kit - 20 1/4" - with 28 Spline Axles |
| 914Sixer |
Nov 28 2025, 05:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,349 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yes it will work IF you have flanges and stub axles. Says they are BACKORDERED.
| Mitox |
Nov 28 2025, 05:33 PM
| mb911 |
Nov 28 2025, 07:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,693 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Mine are full floating and came from PMB
| bdstone914 |
Nov 28 2025, 08:10 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,197 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This kit from JBugs looks like it would work on the 914. Maybe? The sale Price looks good also. https://www.jbugs.com/product/16-2236.html VW 930 Axle Kit - 20 1/4" - with 28 Spline Axles ![]() 914 CVs use two 10mm roll pins. Those are VW CVs with 6 bolts. I would drill two of the holes to 10mm ans install roll pins. Not sure about the axle lenght as VW bug axles are shorter |
| bdstone914 |
Nov 28 2025, 08:13 PM
Yes it will work. Says they are BACKORDERED. I didn’t see the back order status - hopefully they would honor the pricing. Attached thumbnail(s) |
| 914Sixer |
Nov 28 2025, 08:43 PM
Corrected my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them.
Nov 29 2025, 04:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 602 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Correct my yes statement. You need 911 hubs and stubs to make them work. Add about $1k for them. If you have the 911 stubs and hubs along with the 108mm flanges on the transmission side (the same parts you will need for those $595 axles), these will work and are only $30 per axle: https://www.rockauto.com/en/moreinfo.php?pk...288&jsn=475 Here's further discussion on the subject: http://www.914world.com/bbs2/index.php?sho...=368822&hl= This also means you'll need 5 bolt wheels, as the 28 spline hubs only come for the five lugs. |
Lo-Fi Version | Time is now: 29th November 2025 - 11:54 AM |
