| DennisV |
Nov 27 2025, 09:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 794 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Does anyone happen to know the specification (i.e. diameter and total length) for the stud on the front turn signal housing? One of ours is missing the stud and I need to replace it.
There is not separate listing for it in the parts catalog. I have flown back home now, so I don't have access to the car to tear apart the other side and measure it for reference. Thank you. ![]() |
| Spoke |
Nov 27 2025, 10:34 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,274 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
It's a standard metric thread. 6mm dia x 1mm thread pitch I believe.
| dtmehall |
Nov 27 2025, 10:39 PM
Member ![]() ![]() Group: Members Posts: 211 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
the factory only offered that as an assembly
the studs were not available separately same on all the exterior lenses btw |
| doug_b_928 |
Nov 28 2025, 01:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 722 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
If I recall correctly, I think it’s 25mm in length. You can make one by cutting the head off of an M6 bolt.
Lo-Fi Version | Time is now: 28th November 2025 - 11:28 AM |
