| BPic |
Nov 22 2025, 08:53 AM
Member ![]() ![]() Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States
| Literati914 |
Nov 22 2025, 01:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Is there actually anything different about the shift rod itself over a standard one. or is the mounting plate the only difference from a stock set up?
| Ninja |
Nov 22 2025, 01:44 PM
Newbie ![]() Group: Members Posts: 13 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
My Weltmeister (side shifter) is longer than stock beneath the pivot point.
Mine came with a thick aluminum spacer to move the shifter plate up to keep the lever from hitting the floor pan. This add shows the aluminum spacer... |
| 914werke |
Nov 22 2025, 02:25 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,468 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Is there actually anything different about the shift rod itself over a standard one. YesNon chromed rod the rod length above the fulcrum is shorter, below longer Spacer to correct for dimension change in the tunnel Exact same mounting, bolt in NLA for the side shift (IMG:style_emoticons/default/smile.gif) |
| FlacaProductions |
Nov 22 2025, 03:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,085 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
This is good to go for a 74 side shifter, right?
If so...I'll take it. PM Sent. |
| BPic |
Nov 22 2025, 04:09 PM
Yes it is, You may need longer bolts. I might have some that you're welcome to if I find them.
Lo-Fi Version | Time is now: 23rd November 2025 - 01:24 AM |
