> Horn Help Please
kenshapiro2002
post Nov 20 2025, 12:37 PM
So the horn on my new ( to me) 914 doesn’t work. Pulled the 911 horn pad off just now and as you can see, the brown wire is taped off. Wondering why. But at least I know why we have no sound. Where’s it supposed to attach?
barefoot
post Nov 20 2025, 01:04 PM
QUOTE(kenshapiro2002 @ Nov 20 2025, 01:37 PM) *
Should be a tab on the back of the horn button.
kenshapiro2002
post Nov 20 2025, 01:14 PM
QUOTE(barefoot @ Nov 20 2025, 02:04 PM) *
Yep… found it. Now I know why it was taped up… horn works fine… ALL THE TIME!!! It’s hot. Hopefully just the relay?
Garland
post Nov 20 2025, 01:20 PM
Restoration Fanatic
QUOTE(kenshapiro2002 @ Nov 20 2025, 02:14 PM) *
You’re grounding the circuit when that wire makes contact with the wheel, when depressing the horn pad. There should be a male tab on the back of the horn pad, to connect the wire to. Many of the tabs are broken off.
dr914@autoatlanta.com
post Nov 20 2025, 02:05 PM
the lead does NOT go through the hole in the steering wheel!!
QUOTE(Garland @ Nov 20 2025, 12:20 PM) *
something is grounding
QUOTE(kenshapiro2002 @ Nov 20 2025, 12:14 PM) *
kenshapiro2002
post Nov 20 2025, 04:13 PM
QUOTE(dr914@autoatlanta.com @ Nov 20 2025, 03:05 PM) *
Relay didn’t help. Yeah… gotta find where it’s grounding damnit.
kenshapiro2002
post Nov 20 2025, 05:00 PM
I’m wondering if it’s at all because the PO installed a 911 horn button on the 914 wheel.
kenshapiro2002
post Nov 20 2025, 05:18 PM
QUOTE(kenshapiro2002 @ Nov 20 2025, 06:00 PM) *
post Nov 20 2025, 07:48 PM
QUOTE(kenshapiro2002 @ Nov 20 2025, 01:14 PM) *
Swap the horn relay with a headlight motor relay and see what happens.
kenshapiro2002
post Nov 20 2025, 09:54 PM
Would moving the wire from position number one to position number two make a difference?
L-Jet914
post Nov 21 2025, 01:02 AM
Position 2 is the factory location. The tab that connects to the female connector is broken. I've never seen the horn wire in position one. Position 2 grounds when the button/horn pad is depressed. I think where it is currently it is always grounding causing your horn to sound all the time.
chmillman
post Nov 21 2025, 01:26 AM
QUOTE(L-Jet914 @ Nov 21 2025, 08:02 AM) *
kenshapiro2002
post Nov 21 2025, 07:58 AM
QUOTE(L-Jet914 @ Nov 21 2025, 02:02 AM) *
Thanks.
- Lo-Fi Version Time is now: 22nd November 2025 - 12:27 AM
