| dknechtly |
Nov 19 2025, 10:10 AM
Yellow 914 ![]() ![]() Group: Members Posts: 71 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
Does anyone know the case through bolt o-ring size? I split my case and want to use viton. I've searched but had no luck. Thanks
| 914sgofast2 |
Nov 19 2025, 01:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 781 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
No orings are used on Type 4 engine case through bolts.
| dknechtly |
Nov 20 2025, 07:57 AM
Thanks for the reply. These go in between the case halves. The right half inside holes are beveled. I did finally find that they are 8mm ID X 12mm OD X 2mm.
Nov 20 2025, 08:27 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,527 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
No orings are used on Type 4 engine case through bolts. (IMG:style_emoticons/default/agree.gif) There is a vibration damper that belongs on the through bolts between case halves. |
| VaccaRabite |
Nov 20 2025, 12:37 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,811 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Third voice saying there are no o-rings there. Its a hard plastic ribbed damper about an inch long. not an o-ring.
Zach |
| dknechtly |
Nov 21 2025, 05:45 PM
Hmmm... Well. both cases halves are beveled inside. The left side had more sealant. It's been 12 years since I've been in there but I'd swear there were orings. I am aware of the vibation rubber. Guess I'm wrong. Bad memory. Thanks for the replies.
Nov 21 2025, 08:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 591 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Well, the later VW type 1 cases used o-rings on the main studs (earlier type one cases used sealing nuts). Maybe that is what you were remembering?
Lo-Fi Version | Time is now: 22nd November 2025 - 12:26 AM |
