> help-oil strainer won't come out
dlindzey
post Nov 18 2025, 03:44 PM
repeat offender
I am changing oil and got stuck at the oil strainer. The outer piece has come off and i have removed the paper washer that was under it. It was not easy to pull the outer piece off.
I removed what I will call an odd nut that connects to a stud that is now sticking out of the retained portion of the oil strainer. The strainer appears to be aluminum. I can not dislodge this inner piece to get to the strainer and to complete the job as intented.
Is this a common issue? Any solution/ Naturally not forcing the issue.
Replies(1 - 13)
Shivers
post Nov 18 2025, 05:58 PM
Which piece will not come off?
@dlindzey
fiacra
post Nov 18 2025, 06:16 PM
Person.Woman.Man.Camera.TV
A picture would be helpful. It could just be me but that description is confusing
dlindzey
post Nov 18 2025, 07:15 PM
repeat offender
QUOTE(Shivers @ Nov 18 2025, 05:58 PM) *
@dlindzey
it is number 12
dlindzey
repeat offender
@dlindzey
it is number 12
dlindzey
repeat offender
@dlindzey
it is number 12
dlindzey
repeat offender
@dlindzey
it is number 12
dlindzey
repeat offender
@dlindzey
it is number 12
Shivers
post Nov 18 2025, 07:32 PM
Is it number 12? (IMG:style_emoticons/default/lol-2.gif)
Shivers
post Nov 18 2025, 07:39 PM
It is a replaceable part, about 20 bucks. Maybe someone put a sealer between the case and the flange on the strainer.
bkrantz
post Nov 18 2025, 07:48 PM
If you try prying out the strainer, be careful not to gouge or scratch the seating surface in the recess in the engine case.
The other thing that happens is they get hung up on the stud threads. Cheap strainers aren’t made well and often have crappy fit at the studs with sharp edges getting deformed into the threads. Sometimes useful to spin it as if you are unthreading the strainer - even though it’s not threaded. Attached Image
dtmehall
post Nov 18 2025, 07:54 PM
as noted above, there is a danger in prying with scratching the sealing surfaces.
you can use a screwdriver, but be careful where you put the fulcrum point
you can also use a SMALL blade tool to get between the opening in the strainer and pull straight down
good luck!
fiacra
post Nov 18 2025, 10:01 PM
Yeah, been there as well. There's nothing secret holding it on, the flange and and gasket are just stuck to the case. Just take your time and work it free. As already noted, if you damage it a replacement won't break the bank. It has been a while since I had a strainer get really stuck, but I believe I used a gasket scraper to get it free.
- Lo-Fi Version Time is now: 19th November 2025 - 12:58 AM
