> Stuck on what to do next, 76 won't run
Danfox007
post Nov 10 2025, 01:46 PM
I Have a 76 2.0 that has been parked for over 30 years ..I have been going through it trying to get it back in running order fuel tank has been cleaned and coated, new fuel lines, fuel pump, vacuum hoses, plugs rotor, cap, sent injectors in to Mr. Injector to be cleaned and tested. The car will fire andstart for a second, but won't run. Fuel pressure and spark are good, where do I go next?
fiacra
post Nov 10 2025, 02:04 PM
QUOTE(Danfox007 @ Nov 10 2025, 11:46 AM) *
Have you gone through and cleaned all the grounds?
DRPHIL914
post Nov 10 2025, 02:07 PM
Dr. Phil
check the MPS to see if its holding vac, it could be shot and wont start without it working, also ,theCHt-
if you have spark and fuel pressure, could be timing still might be off a bit
Phil
post Nov 10 2025, 02:38 PM
QUOTE(Danfox007 @ Nov 10 2025, 01:46 PM) *
not saying this is correct but it sure sounds like what i went through recommissioning mine 5 years back. it was an L jet that had sat for 16 years.
when time came to start it, she would fire and run for a few seconds. around 4-5 seconds at most.
i had reinstalled the original injectors i had cleaned and then tested.
we diagnosed it was firing on the cold start injector, but the main injectors were kaput despite the cleaning. and testing. basically the pintels get corroded and though they can be cleaned and made to work, this does not last for long before they jam again due to the micro scaled corrosion. between having them cleaned and reinstalling, maybe a month or so they had resumed inoperational state.
i managed to get some NOS l jet injectors. installed them.
it fired and ran.
could be whats going on with you.
ctc911ctc
post Nov 10 2025, 05:44 PM
Start with checking the foundation and then move on to the walls, plumbing etc.
1. Compression - make certain that the compression is correct, that the valves are adjusted.
2. Assuming DJet(if stock it is a DJet) - the plenum MUST be airtight and be able to hold a vacuum - This is an absolute necessity to get the engine to run correctly.
3. Injectors - verify that all of the injectors spray when actuated - I had one fail after sending to a very good injector refurb company - chased this one for a month....great company, the injectors are very old and well, fail.
4. Sensors - the Temp Sensor on the passenger side of the engine - it is buried - often fails and causes all sorts of havoc, it is cheap however, may be frozen in the case - PB Blaster or similar prior to trying to remove
5. Injector pressure - needs to be 29PSI, verify that this is correct - you state it is good, for a carb engine it is around 3PSI, for an injector engine it is very different - these two fuel pumps are sometimes mixed up and cause lots of problems - 29 into a carb - yikes.
6. Dwell - I cannot stress how important this is. I rebuilt the distro using a kit and could not get the dwell to set at 45deg, I bought a refurbished one set the gap, measured the dwell and when the car started, about 10 running problems ( missing, low power, occasional bucking, etc. ) all disappeared.
I found a great deal of symptom-fix information in Dr. 914's book
https://www.autoatlanta.com/Tech-Tips-700-F...PN-RBK7074.html
Nearly every symptom is covered, short money for a great reference.
QUOTE(Danfox007 @ Nov 10 2025, 02:46 PM) *
post Nov 11 2025, 06:41 AM
Start simple and work from there. If you give it starter fluid will it keep running?
As stated above, check if the mps will hold vacuum 17 inhg.
Although plenum leaks are bad, they will just cause a high idle.
When it does run for that moment, does it sound ok or is it running badly?
Does it always start and run briefly?
rfinegan
post Nov 11 2025, 08:44 AM
....second for the starting fluid test (supplemental fuel)
Root_Werks
post Nov 13 2025, 12:21 PM
Village Idiot
QUOTE(rfinegan @ Nov 11 2025, 06:44 AM) *
I'll give that a third vote to try. From what's been stated already, sure sounds like your only firing off the cold start injector. Little spritz of starting fluid to keep it running for 20-30 seconds will help confirm it.
Danfox007
post Feb 23 2026, 01:37 PM
QUOTE(wonkipop @ Nov 10 2025, 02:38 PM) *
it fired and ran.
any way of testing this without buying new ones?
post Feb 23 2026, 04:52 PM
QUOTE(Danfox007 @ Feb 23 2026, 01:37 PM) *
it fired and ran.
http://www.914world.com/bbs2/index.php?showtopic=77265
scroll down to jk76.914's post.
about all you can do.
- Lo-Fi Version Time is now: 23rd February 2026 - 11:35 PM
