> Overspray Removal from Fresh Air Inlet Box
DennisV
post Nov 5 2025, 10:26 AM
Does anyone have a tested method for removing paint from the fresh air inlet box? Ours had quite a bit of overspray on it. I tried:
* Acetone (had done great on everything else)
* Goo-gone
* Goof-off graffiti
Ultimately made it way worse. (IMG:style_emoticons/default/sad.gif) I must have been very embarrassed by the result, as I didn't even take a picture. I'm not sure what this box is made of that is making this so problematic.
Thanks.
friethmiller
post Nov 5 2025, 10:40 AM
I used Lacquer Thinner.
Olympic 914
post Nov 5 2025, 11:25 AM
I had luck using Brasso.
A bit of scrubbing but
didn't hurt the plastic at all.
slowrodent
post Nov 5 2025, 11:31 AM
Black spray paint (IMG:style_emoticons/default/smile.gif)
IronHillRestorations
post Nov 5 2025, 11:47 AM
I. I. R. C.
+1 for just painting it black
914sgofast2
post Nov 5 2025, 01:54 PM
use some red rubbing compound and polish it off. The stuff is made for cutting down old oxidized paint.
DennisV
post Nov 25 2025, 05:53 AM
Closing this out in case it might help someone else.
We also tried lacquer thinner, isopropyl alcohol. Just wasn't helping things. As a couple folks suggested, we ended up painting it. Used this flat black Krylon Fusion all-in-one paint and primer that says it will adhere to plastic. Initial results was a pretty good match. We'll see how well it wears.
Thanks for the suggestions.
2 Members: sixaddict, dtmehall
- Lo-Fi Version Time is now: 25th November 2025 - 01:10 PM
