> 915 /916 mechanical speedo drive, 915 /916 mechanical speedo drive
rgalla9146
post Oct 28 2025, 04:58 PM
Anyone here have a running driving Martin Bott 915 / 916 conversion with mechanical speedo drive ?
My car is up and driving but my mechanical speedo shows 120 mph when GPS says 60.
I've tried other 914 speedos and even borrowed a '72-'73 911 speedo to see if that
was the difference. It wasn't.
A well known instrument restorer suggested the difference I was seeing was outside
the range of normal adjustment.
I'm trying to stay with 914 era parts.
Anyone ?
post Oct 28 2025, 06:54 PM
Can you substitute a 914 drive and try it.
Maltese Falcon
post Oct 29 2025, 05:07 AM
See if California Motorsports (Lake Havasu) has a different 915 drive gear for the problem .
Marty
rgalla9146
post Oct 29 2025, 06:53 AM
QUOTE(mepstein @ Oct 28 2025, 08:54 PM) *
Mark as you know in a 911 chassis the speedo cable is driven straight forward into the
tunnel
A Bott 916 rear cover is arranged just like a 914 with a 90 degree bevel gear on the
rear of the pinion shaft, then another 90 degree adapter on the outside of the
trans (1:1) forward to the cable. That is how mine is assembled.
I think the difference lies with the gear ratio machined onto the tip of the 915 pinion
shaft.
Any chance you can count the number of teeth on a 915 pinion shaft speedo gear ?
If not, I can probably get it from a trans shop...Patrick Motorsport ?
Or someone here ?
post Oct 29 2025, 08:09 AM
Did you try reaching out to Martin? It does sound like a trans gear issue. You can also try James at PMS. He built my MB 916 trans, but mine is an electric speedo. Also check the MB ad in the members vendor section for 914world members that bought the mechanical speedo option.
2 Members: Steve, sixnotfour
- Lo-Fi Version Time is now: 29th October 2025 - 08:10 AM
