| hndyhrr |
Oct 8 2025, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
the pumpkin's gas tank has black flakes in it when I looked with the borescope. Should I have it cleaned(boiled?) out or should I get a new one. If cleaned out do radiator shops do that?
Thanks Renee |
| hndyhrr |
Oct 8 2025, 05:44 PM
the pumpkin's gas tank has black flakes in it when I looked with the borescope. Should I have it cleaned(boiled?) out or should I get a new one. If cleaned out do radiator shops do that? Thanks Renee Welp found out there are no radiator shop still open in Medford, Oregon. I will clean it out myself. (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/beerchug.gif) |
| thomasotten |
Oct 9 2025, 01:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,575 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
We coated the inside of our 924S with the gas tank kit from POR-15. Follow all the steps and it should turn out good. Be sure to check for pinholes near where the gas tank rests on the carpet support, they usually corrode there from the outside.
| mlindner |
Oct 9 2025, 04:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,773 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
I just used POR15 tank sealer and it worked great, takes four days to cure. POR15 has a cleaner to use first, then seal.
| 914werke |
Oct 9 2025, 10:07 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,664 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
| GeorgeKopf |
Oct 9 2025, 02:45 PM
Member ![]() ![]() Group: Members Posts: 260 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
I am in the process of cleaning out my gas tank. I used electrolysis to pull out the rust. Ran the process for a week.
DM me if you want to chat about the process. ![]() ![]() ![]() ![]() ![]() Now I'm going to use the KBS gas tank sealing kit as the final step. George |
| hndyhrr |
Oct 9 2025, 05:55 PM
Thanks guys.
Just bought a new tank, that is the easy way ...... not the cheap way lol. I am thinking i will need to flush out new tank before install. What to use for that? Gas?, soapy water? Renee |
Oct 9 2025, 08:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 793 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Probably a good idea to replace it, especially if the flakes you saw were corrosion.
It's very discouraging to go to all the work to refurbish a gas tank only to have it leak. If you have one leak, how long untill another pinhole pops up? And, I've read that some sealants end up failing. But, don't know, never used it other than a small puncture fixed with some special epoxy putty stuff on a car that wasn't worth making a proper fix. As for cleaning the new tank, either not necessary or you could slosh some gas around inside, especially if you see any dirt from manufacturing. Just looked at a brand new tank and can't see any dirt ir debris inside it. |
| nivekdodge |
Oct 10 2025, 10:15 AM
Member ![]() ![]() Group: Members Posts: 335 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
Not looking to steal the thread but since the big guns are in here, should the op, or can the op convert to threaded AN style fittings all the way back?
kevin |
| Artfrombama |
Oct 10 2025, 10:46 AM
Artfrombama ![]() ![]() Group: Members Posts: 453 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Thanks guys. Just bought a new tank, that is the easy way ...... not the cheap way lol. I am thinking i will need to flush out new tank before install. What to use for that? Gas?, soapy water? Renee Test fit before you add anything flammable to the tank. I bought a new tank, although ordered for a 74 the top bracket and side tab were not there. Removed them from my old tank and welded on the replacement tank. |
| 914Sixer |
Oct 10 2025, 11:24 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,482 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Got a Liland tank today. Will be posting up pictures later today.
| bajafreaks |
May 16 2026, 04:34 PM
Member ![]() ![]() Group: Members Posts: 135 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
| tomeric914 |
May 16 2026, 07:24 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,324 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
| JamesJ |
May 16 2026, 07:37 PM
Member ![]() ![]() Group: Members Posts: 285 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
Things may have changed now, but about 4 years ago I met a 914 owner who purchased a new Dansk tank and regretted doing so due to fitment issues.
Lo-Fi Version | Time is now: 16th May 2026 - 08:12 PM |
