> FS: 8 NOS 10mm Swivel Feet Valve Screws. $149 shipped, German Thorson-Pieper Harded Steel 2.0L Screw. SOLD
post Sep 14 2025, 11:30 AM
Almost impossible to find. Lets you use for 2.0L rocker arms AFTER they have been machined.
paypal.me/markheard1
cgnj
post Sep 14 2025, 04:45 PM
I use these on one of my motors. Side bonus is they are allen head and much easier to adjust valves.
Fazasport
post Sep 15 2025, 04:58 AM
QUOTE(914Sixer @ Sep 14 2025, 01:30 PM) *
What machine work needs to be done to the 2.0 rocker arm in order to make this work on my '76 914-2.0
John Sipay
post Sep 15 2025, 05:37 AM
The thickness of the arm has to be cut down. Have a set done, will get pictures.
914ltd
post Sep 15 2025, 08:25 AM
I made a jig to hold 4 rockers. I used a belt sander to cut the bottom side down to 11.5mm for 8mm 911 wobble feet.
Mark might be able to check this dimension for the 10mm wobbles.
A 24 or 36 grit belt removes the metal relatively quickly. Brad
914werke
post Sep 15 2025, 09:48 AM
Nice.
Keep in mind depending on your geometry if using the OE covers they may need to be "massaged" to avoid the top of the adjuster tapping the cover
post Sep 15 2025, 12:58 PM
Tabari did these differently. He took a little off the bottom and beveled out the center.
zerliq
post Sep 15 2025, 05:44 PM
QUOTE(914Sixer @ Sep 15 2025, 12:58 PM) *
PM Sent. Thanks, Rob
- Lo-Fi Version Time is now: 18th September 2025 - 05:08 AM
