| Artfrombama |
Sep 10 2025, 10:53 PM
Artfrombama ![]() ![]() Group: Members Posts: 453 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Adjusted the valves using the TDC method with satisfactory results but I find it somewhat difficult and takes too long.
The way I’ve always adjusted valves is with a remote starter button and bumping the starter. When the exhaust open, adjust the intake. Then when the intake fully open and starting to close, adjust the exhaust. EOIC Is either correct? (IMG:style_emoticons/default/WTF.gif) If not please explain. |
Sep 11 2025, 05:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,548 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I like the crusty method. Put it in fifth, roll the wheel till a valve of choice is completely compressed (or use the starter, but I think the wheel is easier). Then adjust the opposite valve. So if you compress the exhaust valve on cylinder 4 you would adjust the exhaust valve on cylinder 2.
No TDC, no hoping it is as loose as it can be, no losing track of where you are or have been. |
| Kansas 914 |
Sep 11 2025, 05:24 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
I like the crusty method. Put it in fifth, roll the wheel till a valve of choice is completely compressed (or use the starter, but I think the wheel is easier). Then adjust the opposite valve. So if you compress the exhaust valve on cylinder 4 you would adjust the exhaust valve on cylinder 2. No TDC, no hoping it is as loose as it can be, no losing track of where you are or have been. From the Cap'n: http://www.914world.com/bbs2/index.php?showtopic=28758 |
| VaccaRabite |
Sep 11 2025, 05:44 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,863 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
The way I’ve always adjusted valves is with a remote starter button and bumping the starter. When the exhaust open, adjust the intake. Then when the intake fully open and starting to close, adjust the exhaust. EOIC (IMG:style_emoticons/default/splat.gif) This is not the way to adjust valves. You have no idea at what part of the cycle the valve is in, and the valves do overlap (one is opening while the other is closing). When you adjust a valve, it needs to be FULLY off the cam lobe. Do not adjust valves this way! I also use the Crusty method posted here. I find it a lot faster to not have to get out from under the car. But of the methods you listed, you need to be using the TDC method. Zach |
| GregAmy |
Sep 11 2025, 07:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,659 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Cap'n method, both valve covers off, remote starter button. Print out the card so you don't have to think about it.
Easy peasy. |
Sep 11 2025, 08:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,832 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Nothing wrong with the Capt’n method but it needs to be acknowledged that its application is limited to the cam lobe sharing of the VW horizontally opposed engines.
The tried and true TDC of the compression stroke method, following the engine firing order is universally applicable. |
Sep 11 2025, 08:26 AM
I don't even bother with the 'fast way' using the table of what is adjustable at any given rocked valve. Less chance of me screwing something up, and it really doesn't take long to just go around and rocking the opposites one at a time.
Sep 11 2025, 10:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,648 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
just had a look at the wise words of the Cap, looks like it would take a year
| ctc911ctc |
Sep 11 2025, 01:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
I spent a good deal of time analyzing Krusty's method
http://www.914world.com/bbs2/index.php?s=&...t&p=2793467 I believe this makes things a bit clearer |
| Literati914 |
Sep 12 2025, 08:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,313 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
The simplest way that I've found and IMHO, for the actual adjustment is:
TDC #1 = check Int. & Ex. @ #1 / Int. @ #2 / Ex. @ #4 TDC #3 = check Int. & Ex. @ #3 / Int. @ #4 / Ex. @ #2 done. here's a good video that includes a simple drawing : https://www.youtube.com/watch?v=lfkxlHWZmxM |
| Artfrombama |
Sep 12 2025, 12:09 PM
Thanks to everyone that responded.
I'm wishing I had paint marked my fan and flywheel when the engine was out and the heads were off, find and mark TDC of all the pistons. I think I will continue to use the EOIC method, most familiar to me and I feel just as accurate. I think all the methods discussed here give satisfactory results, totally personal preference. |
| rfinegan |
Sep 13 2025, 07:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,196 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
I'm of the school like emerygt350, we know the lobe is shared with the opposing cylinder.
With the trans in 5th gear and one wheel blocked. 1) Rotate wheel/engine (helper or with you feet) 2)Watch the valve open until fully open (top of lobe) 3)Adjust the apposing valve to desired lash.(at base of lobe) ^^^this works EVERY TIME on ANY CAM PROFILE^^^^ After a few times you will see that the Crusty method will put you on the fewest rotations of the engine and save time knowing which one to adjust next with the lobe lift /base method |
| Dave_Darling |
Sep 13 2025, 09:57 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,339 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I think I will continue to use the EOIC method, most familiar to me and I feel just as accurate. If that's where you adjust the other rocker in the cylinder where one valve is open, that's not a good idea... I use the TDC method. I have found the clearances to be off when I checked with one valve on a cylinder open. --DD |
| neyen14 |
May 6 2026, 09:53 AM
Member ![]() ![]() Group: Members Posts: 109 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States |
With one wheel off the ground and the car in 5th, the lifted wheel does not turn, nor does the engine. The starter does turn the engine and the rotor spins. Wut is wong?
| FlacaProductions |
May 6 2026, 10:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Is the e-brake on?
| neyen14 |
May 6 2026, 10:22 AM
| VaccaRabite |
May 6 2026, 11:03 AM
With one wheel off the ground and the car in 5th, the lifted wheel does not turn, nor does the engine. The starter does turn the engine and the rotor spins. Wut is wong? If the spark plugs are in you have to overcome the basic compression stroke. 5th gear gives you the most advantage there, and I can pretty easily turn even a fresh engine making 150psi compression this way. BUT. It isn't effortless. If you are expecting effortless, you are mistaken. Push harder. If it really does not move, I'd be looking at your brakes. They may be stuck on, and you are just overpowering them as you drive. Or you have a caliper rusted to the rotor. Zach |
| friethmiller |
May 6 2026, 11:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,245 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
| neyen14 |
May 6 2026, 11:36 AM
With one wheel off the ground and the car in 5th, the lifted wheel does not turn, nor does the engine. The starter does turn the engine and the rotor spins. Wut is wong? If the spark plugs are in you have to overcome the basic compression stroke. 5th gear gives you the most advantage there, and I can pretty easily turn even a fresh engine making 150psi compression this way. BUT. It isn't effortless. If you are expecting effortless, you are mistaken. Push harder. If it really does not move, I'd be looking at your brakes. They may be stuck on, and you are just overpowering them as you drive. Or you have a caliper rusted to the rotor. Zach With the car in neutral wheels spin freely, with e brake alone I get zero movement. When I put it in 5th, I get slight turn then gear.... in either direction. I'd take the plugs out but doesn't feel like I'm bucking up against compression.... total gear |
| Dave_Darling |
May 6 2026, 01:43 PM
"Slight gear"? "Total gear"? Not sure what you mean.
If the car is in gear and the clutch is good, then turning the transmission should turn the crankshaft. Could there be something wonky with your differential? Limited slip? Welded diff? --DD |
Lo-Fi Version | Time is now: 6th May 2026 - 02:12 PM |
