> Front shock retaining ring/nut removal?, How do remove the front shocks retaining ring, it doesn’t appear to have any slots?
madrider
post Aug 30 2025, 01:32 PM
Replacing my front shocks. I’m not sure how to remove the metal retaining ring/nut from current shock? Did a quick search, but I don’t see any slots, threads or something visible to grab for the removal? Looks press fit? I’ve attached pics, thanks for help!Attached Image Attached Image
914werke
post Aug 30 2025, 02:10 PM
Its a Bilstein strut there is a roll pin at the bottom of the strut body.
post Aug 30 2025, 08:17 PM
This the ONLY replacement you can use
914werke
post Oct 27 2025, 12:21 AM
Aside from the (911) mono-tube inserts, does anyone know where you can source small parts for this style housing?
I need the oil seals & at lease one of the rubber bump stops.
Oh & new roll pins
Shivers
post Oct 27 2025, 04:28 AM
The bilsteins came in a couple different versions. Mine are green tops, these seals in the pic are elephants. I can see no numbers in your pic and I do not know at a glance if your seals are factory, which would make them early or someone else’s seals and they could be the later bils. I put a link to elephant racing, pretty sure you can get what you need there.
https://www.elephantracing.com/porsche/911/...mhLjIZL7I_QnmTd
@madrider
stownsen914
post Oct 27 2025, 06:15 AM
It's been a while but I recall that there are two different styles of the seal caps for Bilsteins, the regular one and an RSR style one that is smaller profile and allows for more shock travel. When I replace mine, Elephant had both styles.
914werke
post Oct 27 2025, 11:46 AM
Thanks that does look like an option If the /4 strut housings are considered "late" per their website.
To be clear they are only offering a non OE version of the Oil seal. I guess Ill have to call to see if they can help with the other little items.
(IMG:style_emoticons/default/bye1.gif)
dr914@autoatlanta.com
post Oct 27 2025, 12:20 PM
Pretty terrific that you have the bilstein suspension package on your 914, very few were ordered with it, we sell about twenty strut replacements per year for that setup
QUOTE(madrider @ Aug 30 2025, 12:32 PM) *
post Oct 28 2025, 04:57 AM
@914werke
' date='Oct 27 2025, 10:46 AM' post='3230216']
[/quote]
Call Bilstien service center in Poway CA 1 858 386 5900 . I bought the top rings from them directly a few years ago.
914werke
post Oct 28 2025, 10:59 AM
QUOTE(bdstone914 @ Oct 28 2025, 03:57 AM) *
(IMG:style_emoticons/default/aktion035.gif)
IronHillRestorations
post Oct 28 2025, 08:07 PM
I. I. R. C.
@madrider I still have those Bilstein front inserts if you need some, PM me
914werke
post Oct 30 2025, 10:10 AM
Although I did search, I missed this thread found on the Bird (Thanks Jeff) which covers the R&R pretty thoroughly (IMG:style_emoticons/default/first.gif)
https://forums.pelicanparts.com/porsche-911-technical-forum/1132669-bilstein-strut-housing-internal-bushing-replacement.html
kostritzer
post Jul 7 2026, 08:00 AM
QUOTE(914werke @ Oct 28 2025, 09:59 AM) *
Hey Rich, did you have any luck getting those seals from Bilstein? I'm currently on the hunt for a pair as well.
post Jul 7 2026, 08:36 AM
@kostritzer
date='Jul 7 2026, 07:00 AM' post='3264380']
[quote name='914werke' post='3230355' date='Oct 28 2025, 09:59 AM']
[quote name='bdstone914' post='3230311' date='Oct 28 2025, 03:57 AM'] Call Bilstien service center in Poway CA 1 858 386 5900 . I bought the top rings from them directly a few years ago. [/quote]
[/quote]
[/quote]
Did you call Bilstein at 1(858)3865900 ?
- Lo-Fi Version Time is now: 7th July 2026 - 12:42 PM
