BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 682 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
So I'm replacing my front hood gasket and treating the rust in the channel, when I discovered that the DAPO has struck again. (IMG:style_emoticons/default/headbang.gif)
At some point, the driver's side (left) front hood hinge bolt must have broken off, and it was "repaired" poorly. I need a replacement. Does anyone have a good, stock front left hood hinge assembly for sale? Preferably in Alaska Blue Metallic, but I'll take any color as long as it's in good shape. I'll even take a matching pair, if necessary. At a minimum, I need the hinge bolt (part #914-512-191-10) and the left-side hood hinge bracket (part #914-511-037-10), which is the part that bolts to the body (the part that bolts to the hood appears to be fine). Please let me know what you have. Thanks! |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,090 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
So I'm replacing my front hood gasket and treating the rust in the channel, when I discovered that the DAPO has struck again. (IMG:style_emoticons/default/headbang.gif) At some point, the driver's side (left) front hood hinge bolt must have broken off, and it was "repaired" poorly. I need a replacement. Does anyone have a good, stock front left hood hinge assembly for sale? Preferably in Alaska Blue Metallic, but I'll take any color as long as it's in good shape. I'll even take a matching pair, if necessary. At a minimum, I need the hinge bolt (part #914-512-191-10) and the left-side hood hinge bracket (part #914-511-037-10), which is the part that bolts to the body (the part that bolts to the hood appears to be fine). Please let me know what you have. Thanks! I saw one in the shop but have to check which side it fits. I have a parts car but it will be at least a couple weeks before I start pulling parts from it. I should have all the hardware |
BillC |
So I'm replacing my front hood gasket and treating the rust in the channel, when I discovered that the DAPO has struck again. (IMG:style_emoticons/default/headbang.gif) At some point, the driver's side (left) front hood hinge bolt must have broken off, and it was "repaired" poorly. I need a replacement. Does anyone have a good, stock front left hood hinge assembly for sale? Preferably in Alaska Blue Metallic, but I'll take any color as long as it's in good shape. I'll even take a matching pair, if necessary. At a minimum, I need the hinge bolt (part #914-512-191-10) and the left-side hood hinge bracket (part #914-511-037-10), which is the part that bolts to the body (the part that bolts to the hood appears to be fine). Please let me know what you have. Thanks! I saw one in the shop but have to check which side it fits. I have a parts car but it will be at least a couple weeks before I start pulling parts from it. I should have all the hardware Unfortunately, I can't really wait a couple of weeks. I'm signed up for an event in a couple of weeks and need to get the car back together before then. Anyone else have the parts? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,041 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I’m pretty sure I have some. One side had a bolt break off in the threads but if I remember correctly, that’s probably something you can handle. Free if I have them. Might be a day or two before I check the stash.
I should have the hinge bolt as well. |
BillC |
I’m pretty sure I have some. One side had a bolt break off in the threads but if I remember correctly, that’s probably something you can handle. Free if I have them. Might be a day or two before I check the stash. I should have the hinge bolt as well. Yup, no problem drilling out a broken bolt and restoring the threads. If I have to, I could fix this one, but it would have to be welded up first -- the DAPO drilled it out off-center, and then jammed an SAE screw into it. Which also explains why the hood never lined up quite right. |
Lo-Fi Version | Time is now: 29th August 2025 - 06:21 PM |
