FIDO914 |
I'm new here ... Group: Validating Posts: 0 Joined: 11-July 25 From: Central IL Member No.: 28,879 Region Association: None ![]() |
We are the 2nd owner of this great running car, since the fall of 2016. The original owner received it when she graduated from college. We are retiring to FL and do not have enough garage space to store inside the garage. That is the only reason we are selling.
This car was totally dissassembled, every part sandblasted if necessary, epoxy primed, and repainted. All mechanical work and reassembly done by Brad Mayeur and Mike Hanson of 914 Ltd. It does not use or drip oil!! You may e-mail Brad Mayeur if technical details are needed. A factory installed front and rear sway bar is a very unique feature on this 1.7 car. Fuel system has the stock fuel injection system. Ignition is now electronic. Fuchs rims, Michilien Defender 195/R15 tires. Odometer shows 89,000. This is a reliable car, you may choose to fly into Peoria International Airport (PIA) and drive it home to California or wherever. Currently located in Central Illinois between Peoria and Galesburg. Note the pictures under the car--it was mostly like that in 2016! Very clean and tight. Mike fixed the infamous "hell hole" and the jack lift points with new metal as needed. One spot of rust on the lower rear left quarter panel that I may get around to, as a result of not properly painting the interior of the left rear quarter panel. That interior spot was re-painted several years ago and sealed. There is also one tiny "dink" in the hood from the gas cap not being installed correctly before closing the hood. $38,000 cash or you arrange for shipping after check clears. Additional photos are available. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Attached File(s) ![]() |
Lo-Fi Version | Time is now: 13th July 2025 - 08:22 AM |
