s13u74cr4 |
Newbie ![]() Group: Members Posts: 29 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest ![]() |
Working my way through new lines and see one of the fuel rails is bent slightly. Maybe not a problem but figured I would ask while out.
Ishley |
Member ![]() ![]() Group: Members Posts: 233 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest ![]() ![]() |
Not an issue… but if it bothers you is should be pretty easy to find a straight one out there.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,039 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Use a vice to squeeze it flat. That bend is not an issue
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,102 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Cosmetic
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
It's fine, don't mess with it unless that is the VERY last thing you need to do to the car.
Lo-Fi Version | Time is now: 13th July 2025 - 08:34 AM |
