> Parking Brake Firewall Tubes, Looking for tubes
SteveNMaine
post Jul 10 2025, 02:18 PM
Does anyone know of a source for the parking brake tubes that go through the rear firewall?
Ishley
post Jul 12 2025, 10:17 AM
I ended up making mine. I ordered steel tubing from McMaster Carr. I used a torch to carefully bend the passenger side. It needs a gentle 90 degree. I think I made 2 attempts before I got it right. The Clevis on the end of the cable has to slide thru so the bend is critical. I flared the ends in the engine bay using a torch.
The tubing is Smooth-Bore Seamless Steel Tubing 15 mm OD, 1.5 mm Wall Thickness, 1 M Long.
I couldn’t find a source so that’s what I had to do.
Flyinlow
post Jul 13 2025, 08:40 AM
Flyinlow
QUOTE(SteveNMaine @ Jul 10 2025, 01:18 PM) *
Restoration design sells the tubing
- Lo-Fi Version Time is now: 13th July 2025 - 09:03 AM
