Shantb13 |
Newbie ![]() Group: Members Posts: 3 Joined: 20-April 18 From: Fullerton Member No.: 22,057 Region Association: Southern California ![]() |
any good shops near fullerton area in north oc ? trying get more power out of the 1.8 thanks guys to the page ! (IMG:style_emoticons/default/slap.gif)
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,317 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
AASE Motors 1104 E. Elm Avenue, Fullerton, CA. 92831; 714.770.8127 Allen is one of the best. (IMG:style_emoticons/default/beerchug.gif)
Ron914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California ![]() ![]() |
MedFly914 |
Newbie ![]() Group: Members Posts: 42 Joined: 10-July 20 From: Alhambra Ca Member No.: 24,478 Region Association: Southern California ![]() |
Marcs German Auto. MArc is the best!
Address: 633 W Valencia Dr a, Fullerton, CA 92832 Phone: (714) 458 1857 |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,914 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Talk to Clay at Scott's Independent in Anaheim.
Scott has a great Olympic Blue 2.0... They've done great work with my 67 911. https://www.scottsindependent.com 1885 S Santa Cruz St, Anaheim, CA 92805 clay@scottsind.com (714) 634.2027 |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
any good shops near fullerton area in north oc ? trying get more power out of the 1.8 thanks guys to the page ! (IMG:style_emoticons/default/slap.gif) How much power? (or maybe I should ask budget) What induction are you running? Do you need someone to pull the motor or are you doing that yourself? |
JamesM |
he just doesn't do fuel injection only carburetors . That should be a deal killer right there. why limit your build when SO much better is available. I just delivered a built 2.3 with full aftermarket EFI yesterday. Absolute beast of a motor that also accelerates from 1800 in 5th gear going uphill at 8000ft elevation and pulls past 6500rpm. EFI adds SO much to the drivability and day to day usability of the car that it shouldn't even be a question. |
Ron914 |
he just doesn't do fuel injection only carburetors . That should be a deal killer right there. why limit your build when SO much better is available. I just delivered a built 2.3 with full aftermarket EFI yesterday. Absolute beast of a motor that also accelerates from 1800 in 5th gear going uphill at 8000ft elevation and pulls past 6500rpm. EFI adds SO much to the drivability and day to day usability of the car that it shouldn't even be a question. It was actually not bad I had them assemble my bottom end for me and he bench tested and broke it in only used his cabuerator set up on it . I assembled everything else and installed the motor with its original D-Jet FI . This was a big project for me and I still am working out some bugs dialing in the D-jet and passing California smog unfortunately . I had never assembled a motor on my own so it was worth it to have them put the lower end together for me . No leaks seems solid and they honored a previous quote given to the guy I purchased the car from . The challenge with car when I bought it was the motor had already been disassembled and my strengths were not in mechanics . I really wanted to do it myself but had no one to guide or assist me nor the tools and felt the lower end would better to be left to a professional . also I was getting quotes of10K + to do it for me from some local shops and just couldn't afford that much . Only time will tell if it was a good or just ok job . |
Ron914 |
Here is a copy of my build receipt . As you can see I got what I thought was a very fair reasonable bottom end assembled and tested . He even suggested I swap out the heavy new stock rods I provided for H-beams . Not sure how much this help but the cost was reasonable again for around $300 . he suggested I lighten my new balanced flywheel I purchased from Jorge at European motor works in Hawhorne but I read that would make it harder to take off from a light so I went the Beams as a upgrade .
Lo-Fi Version | Time is now: 9th May 2025 - 01:51 AM |
