> 914 Thermostat, Restoring 914 Thermostat
SteveNMaine
post Feb 9 2025, 06:26 AM
Hey, has anyone restored the compressed shape of a 914 thermostat? The one I have has expanded and does not appear to have any leaks.
I have removed the solder on the threaded end which revealed a ball bearing. I removed the ball bearing and tested for leaks by compressing the unit and plugging the hole. It kept the semi-compressed shape for several hours and when I removed the plug, air rushed in and it expanded again.
Is there a way to restore it to its completely compressed shape at idle so-to-speak?
post Feb 9 2025, 08:55 AM
Not really.
Krieger
post Feb 9 2025, 09:37 AM
Awesome powder coating makes brand new and correct ones for our car. A few years back I sent them an original one of my 914 they "restored". I believe they reused the ends of mine and replaced the center bellows and whatever gas is inside. It was almost the same cost as one of their new thermostats.
Jack Standz
post Feb 9 2025, 01:18 PM
I have not restored one. I think Hot VWs did an article on it years ago that you might find in their archives.
But, it looked tedious, so I've collected working ones from any junkyard motors over the years, including VW buses.
post Feb 9 2025, 01:45 PM
https://www.awesomepowdercoat.com/
post Feb 9 2025, 01:55 PM
I am probably in the minority here, but my recent (2 years ago) 2056 build I did not have a working t stat and thought I would try things out and see how it goes.
Well, it works great without the t stat. Warms up very quickly
so far as repairing the original, not sure if it's possible. AFAIK it is a sealed unit
914sgofast2
post Feb 9 2025, 08:32 PM
The originals can be repaired if the bellows does not have hairline cracks. But after 50+ years, good luck with that. The "magic" fluid used in the thermostats is simply denatured rubbing alcohol. I remember finding an article somewhere on how to fix them on either the 914World.com, PelicanParts.com, or on the Samba.com websites. You will need some good soldiering skills to do it properly. I found it easier to just buy a new thermostat from AwesomePowdercoat.com.
SteveNMaine
post Feb 10 2025, 07:11 AM
QUOTE(914sgofast2 @ Feb 9 2025, 09:32 PM) *
Yes, I found those restore/repair instructions as well. I am going to try to fix it before I order a new one.
ClayPerrine
post Feb 10 2025, 12:11 PM
And if you do use them, please check them to make sure they work. Having the flaps stay closed could potentially ruin your engine.
So with the flaps connected, use a heat gun to warm up the thermostat and make sure the flaps open up fully.
DC_neun_vierzehn
post Feb 10 2025, 07:59 PM
QUOTE(JeffBowlsby @ Feb 9 2025, 02:45 PM) *
I see a few parts for 914s, but I don’t see a thermostat.
https://www.awesomepowdercoat.com/type-iv-p...hermostat-parts
jvmarino
post Feb 10 2025, 08:24 PM
https://www.awesomepowdercoat.com/porsche-thermostats
SteveNMaine
post Feb 13 2025, 11:58 AM
QUOTE(SteveNMaine @ Feb 9 2025, 07:26 AM) *
I went through the procedure on www.ratwell.com/technical/Thermostats.html and it worked perfectly.
SteveNMaine
post Mar 28 2025, 04:22 AM
I was able to restore it.
brant
post Mar 28 2025, 09:14 AM
better to run a working thermostat than to leave it off entirely.
your motor... but the warm up difference does promote longevity of the motor.
post Mar 30 2025, 09:04 AM
Hey nice rack! -Celette
I repaired one. It worked but I would rather purchase a new one. I have purchased from Awesome Powder Coat. Great experience.
Puebloswatcop
post Mar 30 2025, 07:09 PM
I agree with Rick. I too repaired one once. The results were a bit disapointing. It worked but would never open the flaps completely. So it is worth the $144. at APC
SVG223
post Mar 30 2025, 09:58 PM
I've got one on the way from Awesome Powder Coat. I don't know how long it has been driven without one. It takes way too long to warm up without it.
Ron914
post Dec 18 2025, 02:14 PM
Has anyone purchased one of these yet .Almost $100 difference ?
Ron914
post Dec 18 2025, 02:19 PM
I now see what I missed
porschetub
post Dec 18 2025, 06:11 PM
QUOTE(Ron914 @ Dec 19 2025, 08:19 AM) *
Do you mean the one that AA sell ?, they say ( George ) that they have had no issues with them but they just say that about all sorts they sell so take that as you like ,these unit have no "failsafe" like the OEM one , if they fail the cooling flaps close and the result isn't nice .
Best to research as I did certainly not the best option to save $100 IMO.
cheers.
- Lo-Fi Version Time is now: 19th December 2025 - 11:27 AM
