> Push rol tube removal, Is there a tool to pull them??
PaIsa
post Jan 1 2025, 09:25 AM
So I tried to replace the o-rings on the push rod tubes. I was able to pull 3 out of the 8 tubes using pliers but I cannot believe that there is not an easier and more efficient way of pulling those tube out. Not saying that using pliers, even when being careful, there is a risk of damaging the tube.
Does anyone know of a tool to get them out? I would see some kind of expanding device that fits inside of the tube with a kind of slide hammering device to get them out. I am pretty sure that someone that does this routinely will have a tool!
rfinegan
post Jan 1 2025, 10:05 AM
I have had pretty good luck wrapping a shop rag around the push rod tube (360 degrees) and with a pulling a twisting motion, the pushed will pull out. No damage to even the thinnest push rod tube
technicalninja
post Jan 1 2025, 10:36 AM
Get them to rotate first, I use lots of WD/40 here.
If I can "break them loose" 1/2 the battle is won!
The rag idea is a good one as well!
GregAmy
post Jan 1 2025, 11:08 AM
Not helpful to your immediate problem, but I'm a big fan of Chris' stainless PR tubes with a welded ring against which to leverage them out. They seal nice, too.
https://tangerineracing.com/shop/ols/produc...s-pushrod-tubes
Aerostatwv
post Jan 1 2025, 11:33 AM
I crack them loose with a pair of vice grips by twisting first to break the friction and then slide them out. You can put a rag around the tube so as not to mar the finish, but has never been an issue for me.
Jack Standz
post Jan 1 2025, 03:31 PM
What everyone else said and have had good luck with these:
https://www.harborfreight.com/10-in-adjusta...iers-70581.html
post Jan 1 2025, 03:43 PM
QUOTE(GregAmy @ Jan 1 2025, 12:08 PM) *
anything from Tangerine is a well engineered product. and Chris is a great guy
PaIsa
post Jan 2 2025, 10:05 AM
QUOTE(rfinegan @ Jan 1 2025, 10:05 AM) *
Tried again this morning with a rag but still not able to pull them out. Made sure they were turning freely before trying to pull them. Maybe my rag is to ''soft'' or I am not wrapping right!
Anyway I will put that on the ice for now and work on something else.
cgnj
post Jan 2 2025, 10:51 AM
Hose pilers are your friend.
porschetub
post Jan 3 2025, 07:53 PM
QUOTE(cgnj @ Jan 3 2025, 05:51 AM) *
(IMG:style_emoticons/default/agree.gif) that's what I use ,if they don't work most likely some clown has gunked them up with sealer that is not required , seen it many times (IMG:style_emoticons/default/sad.gif) .
Buy the correct seals for your motor and lube them with engine oil and locate in the bores then push and rotate ,the last bit may require the waterpump pliers for them to pop in ,you will be good ,cheers.
PaIsa
post Jan 3 2025, 09:31 PM
QUOTE(cgnj @ Jan 2 2025, 11:51 AM) *
Pliers were the tool I used with no luck! Will make another try before putting the engine back in the car.
post Jan 4 2025, 09:27 AM
Before reinstalling them with the proper viton O-rings, make sure the bores in the heads are perfectly smooth to ensure a good longterm leak free engine. (IMG:style_emoticons/default/smile.gif)
post Jan 4 2025, 09:29 AM
Strap Wrench!
brant
post Jan 4 2025, 09:33 AM
QUOTE(PaIsa @ Jan 3 2025, 08:31 PM) *
You have no choice
You should not put the motor into the car now that this tube is molested
It will leak for sure
Replace it
Buy a new or clean used one
Screw the rag
Clamp down and grab it
Ignore the damage to the tube
Get it out
Clean the rtv that the idiot used to install it
Put the replacement tube in with viton seals and no rtv
KELTY360
post Jan 4 2025, 10:47 AM
914 Neferati
QUOTE(brant @ Jan 4 2025, 07:33 AM) *
You have no choice
Replace it
Screw the rag
Get it out
(IMG:style_emoticons/default/agree.gif) Solid advice. Sounds like the voice of experience.
technicalninja
post Jan 4 2025, 12:51 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
I grease the crap out of the O-rings with my Smurf grease.
OP, some bottom feeder probably glued those with something.
You have to change that crap now. Get another set of tubes if yours get trashed.
The bores they fit into in both the case and the heads should be spotless with zero ridge in them.
post Jan 4 2025, 08:23 PM
I have had pretty good luck beating them back into shape after damage on removal. Just slid a deep well socket into em and beat them with a dead blow.
PaIsa
post Jan 6 2025, 06:15 AM
I will probably get back at it this week end with my son. A fresh set of eye and hand could be what I need!
cgnj
post Jan 6 2025, 06:22 AM
It is difficult to fit pliers or vice grips between the pushrod tubes. Hose pliers will grip the circumference of the pushrod tube.
https://www.harborfreight.com/3-piece-long-...iers-37909.html
PaIsa
post Feb 13 2025, 12:34 PM
Just to close this, I finally ended up buying a set of tubes before trying to get the ones currently on the engine out to replace the o-rings.
Was finally able the get all of them out, made sure that everything was clean and reinstall a mix of new and old tubes with brand new o-rings.
I was able to salvage a few tubes that will go in the spare parts box.
We will see once I get the engine back in the car and get it started to see if there are still leaks.
- Lo-Fi Version Time is now: 1st April 2026 - 03:44 PM
