> Engine swap starter choice?, high torque starter suggestions please
slowrodent
post Dec 8 2024, 06:38 PM
Hi all... Was wondering what starting motor is the starter of choice for larger displacement engine swaps... Mine is/will be a 3.2 v6 and my current 914 starter is just not happy... Would like to hear what others have chosen... Thanks to all in advance..
Kevin (IMG:style_emoticons/default/santa_smiley.gif)
Replies(1 - 6)
wndsrfr
post Dec 8 2024, 08:02 PM
Bosch SR68X...
bkrantz
post Dec 8 2024, 08:14 PM
I got one of these, from Hi Torque. Overkill for my 2056 but it was the best option for me.
https://www.hitorque.com/Gear_Reduction_Sta..._p/imi-101n.htm
ClayPerrine
post Dec 9 2024, 05:51 AM
QUOTE(bkrantz @ Dec 8 2024, 08:14 PM) *
I run one of these on the 4.0L motor. It works great.
I put an SR68x on the original six. It worked fine, but it was not the correct factory starter. I have replaced it with an SR19x starter.
VaccaRabite
post Dec 9 2024, 09:17 AM
En Garde!
Highly dependent on the transmission you are using.
If a 901, using a 911 starter makes for a big power jump over the /4 starter.
I have been using one of the IMI-155 starters that Pelican sells now for about a decade. Spins my 2.3 way faster then a stock 914 starter, and weighs a good bit less too.
Zach
BillJ
post Dec 9 2024, 09:26 AM
That hi torque starter is what i use. Great unit
slowrodent
post Dec 9 2024, 11:59 AM
oops..... as indicated, i should have specified stock 914-901 transmission...Kennedy adapter for engine-trans.
- Lo-Fi Version Time is now: 16th September 2026 - 04:35 AM
