| bdstone914 |
Nov 27 2024, 10:42 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Got this.
Attached thumbnail(s) |
| Detroit |
Nov 27 2024, 11:34 AM
Member ![]() ![]() Group: Members Posts: 95 Joined: 28-December 16 From: Detroit metro area Member No.: 20,709 Region Association: Upper MidWest
Seems like it'll be hard to use bolted to the ceiling like that...
| sb914 |
Nov 27 2024, 11:43 AM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,621 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
Did it come from Australia?
| DennisV |
Nov 27 2024, 12:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 884 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Seems like it'll be hard to use bolted to the ceiling like that... (IMG:style_emoticons/default/lol-2.gif) |
| 914werke |
Nov 27 2024, 12:08 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
did it come with peripherals for the T4 heads?
| technicalninja |
Nov 27 2024, 12:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
An "updraft" flow bench!
Didn't think you were "big" into engines! I'm envious! (IMG:style_emoticons/default/ninja.gif) |
Nov 27 2024, 01:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,571 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Is it something like the Super Fly?
| 76-914 |
Nov 27 2024, 02:09 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Bruce, I know you're pleased with your purchase but I gotta tell you that flimsy assed dolly will never bear the load of that big blue machine you need to move. (IMG:style_emoticons/default/huh.gif)
| jim_hoyland |
Nov 27 2024, 02:17 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,041 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
https://superflow.com/product/sf-1020-probench/
“The SF-1020 measures and records air flow at OEM engineering accuracy, faster than any other flowbench on the market. It can test up to 240 hp (179 kW) per cylinder at test pressures up to 65” (165 cm) of water. The unique variable flow orifice adjusts flow range between 25 cfm and 1,000 cfm (12 – 472 l/s), based on FlowCom™ input, to fit the valve size or valve lift. The SF-1020 comes standard with our FlowCom™ digital airflow measurement system for accurate, repeatable and fast testing. FlowCom™ ensures accurate digital airflow measurement and control by automatically measuring test pressure and temperature; then presenting corrected flow data on the easy-to-read, precision display. This saves users considerable time when compared with standard manometer type benches that require users to make calculations to achieve corrected flow numbers. The included automatic motor controller maintains constant test pressure without the use of knobs and valves and it also helps extend motor life by reducing heat generated during operation. Reduced heat means that operators can run for longer durations than benches lacking the motor control feature. “ |
| fixer34 |
Nov 27 2024, 02:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,405 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Looks like a neat new 'toy', but I gotta ask what you are holding up with the yellow nylon rope threaded thru barbell weights, and especially connecting rod ends on a type 4 crankshaft.
| Shivers |
Nov 27 2024, 05:53 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| Puebloswatcop |
Nov 27 2024, 06:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,701 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Hey Bruce I was thinking How you'd be getting a headache using it upside down like that, but then discovered the magic to turn in right side up.....nice score
| fiacra |
Nov 27 2024, 06:59 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 708 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
Wow...tough crowd. Congratulations. When can I borrow it (IMG:style_emoticons/default/biggrin.gif)
| bdstone914 |
Nov 30 2024, 11:37 PM
@914werke
date='Nov 27 2024, 12:08 PM' post='3179160'] did it come with peripherals for the T4 heads? [/quote] It did not. Came from an exhaust company that K & N bought. have many accessories and plan to make the adapter plate to do T4 heads for a built we are doing. And plan to test a performance header with heat boxes. |
| bdstone914 |
Nov 30 2024, 11:38 PM
@fiacra
' date='Nov 27 2024, 06:59 PM' post='3179224'] Wow...tough crowd. Congratulations. When can I borrow it (IMG:style_emoticons/default/biggrin.gif) [/quote] We can talk. |
| bdstone914 |
Nov 30 2024, 11:40 PM
Looks like a neat new 'toy', but I gotta ask what you are holding up with the yellow nylon rope threaded thru barbell weights, and especially connecting rod ends on a type 4 crankshaft. The yellow rope with weights is counter weights to make up for the broken garage door spring |
| bdstone914 |
Nov 30 2024, 11:43 PM
@76-914
' date='Nov 27 2024, 02:09 PM' post='3179176'] Bruce, I know you're pleased with your purchase but I gotta tell you that flimsy assed dolly will never bear the load of that big blue machine you need to move. (IMG:style_emoticons/default/huh.gif) [/quote] That is temporary. It weights 600 lb. has some tiny ass casters that do near nothing. Used the HF furniture dillys to unload it from the trailer |
Lo-Fi Version | Time is now: 1st April 2026 - 11:52 PM |
