Fuchs Center Caps, Center bore diameter |
Mowog4 |
Oct 12 2024, 01:13 PM
Member Group: Members Posts: 316 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
Hi, I am ordering a set of custom wheels and want to use A factory center cap. Anyone have an idea of what the center for the wheel should be.
Thanks, Ed |
Mikey914 |
Oct 12 2024, 07:04 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What do you need ? I have sone variations I made.
May have what you need. Mark |
Mowog4 |
Oct 12 2024, 08:52 PM
What do you need ? I have sone variations I made. May have what you need. Mark Hey Mark I am looking for aluminum Porsche center caps that came on the Fuchs wheels. I am having a set of wheels manufacturer for me in Europe, I’m trying to figure out what size to bore the center hole so I can polish and use original center cups. |
technicalninja |
Oct 12 2024, 09:31 PM
Advanced Member Group: Members Posts: 2,074 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
60mm is what I measure on both a set of real Fuch 4 lug and clone copy 5 lugs.
There may be differences I'm not aware of. |
Mowog4 |
Oct 13 2024, 04:09 AM
brant |
Oct 13 2024, 09:20 AM
914 Wizard Group: Members Posts: 11,823 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
4 or 5 bolt Fuchs?
There are two different sizes of 5 bolt center caps. (Early and late) |
rgalla9146 |
Oct 13 2024, 09:24 AM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
sorry, couldn't find my metric ruler quickly ...in a time pinch
Attached thumbnail(s) |
rgalla9146 |
Oct 13 2024, 09:26 AM
and the other
Mowog4 |
Oct 13 2024, 10:40 PM
technicalninja |
Oct 13 2024, 11:01 PM
and the other Thank you so much, this is great. I think I will go for the larger diameter since I’m going to run a larger wheel. Thanks for the effort. Don't choose that way... If you have the ability to order what you want, I'd order the more popular size in caps. You also should check with your wheel manufacture, if one of the sizes is "standard" changing size might create an upcharge. I would want to "see" both sizes so a bit of image manipulation might be worth it. One of the sizes (smaller) also fits 4 lug caps which are different than 911. I have a question as well. @brant What denotes early vs late for 911 wheels? |
brant |
Oct 14 2024, 07:30 AM
Somewhere around 70-71 I believe
Used to know Would have to do a little research Old caps were 3 prong as pictured above |
Mikey914 |
Oct 14 2024, 05:01 PM
Sorry, the caps I made were for the 4 lug Fuchs.
chmillman |
Oct 15 2024, 10:05 AM
Member Group: Members Posts: 58 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe |
Put new tires on my 7x15 Fuchs today, measured the cap lip inside, it was 71mm.
Lo-Fi Version | Time is now: 21st December 2024 - 08:39 AM |
