> WTB: Lower Front Cross Panel - FOUND, Passenger Section
DennisV
post Sep 5 2024, 06:57 AM
Looking for a small section of the lower front cross panel (914-502-031-12) on the passenger side where the bumper mounts. I know it's a long shot, but thought maybe someone had a section left over from their own repair or a parts car.
Uncovered a very sloppy repair from a PO. They didn't even include the bottom hole to mount the bumper!
Thank you.
P.S. I'm aware that complete cross panels are now available from Restoration Design. That is great, but I'd like to avoid wasting a majority of a panel and the expense associated with buying and shipping it.
peteyd
post Sep 5 2024, 02:48 PM
I have this piece I can cut off.
let me know if it fits the bill
post Sep 8 2024, 08:07 AM
@DennisV Hey Dennis, in case you are not aware, Chris Foley sells the bumper brackets that hides behind that area. When you cut out this beautifully executed repair (IMG:style_emoticons/default/unsure.gif) , you may find other problems...
Found out Chris was making these after having fabricated mine for a similar repair... (IMG:style_emoticons/default/rolleyes.gif)
Here is the link:
https://tangerineracing.com/shop/ols/produc...-reinforcements
Good luck! (IMG:style_emoticons/default/smash.gif)
DennisV
post Sep 9 2024, 08:12 AM
QUOTE(Montreal914 @ Sep 8 2024, 07:07 AM) *
Here is the link:
Thanks for pointing that out. I thought I was OK on that front. Upon closer inspection of the Tangerine part, it looks like the frunk side and top are there but the bottom was lost along with the lower bolt hole. So much for a quick sheet metal repair!
It looks like R-D offers them too.
friethmiller
post Sep 9 2024, 08:21 AM
I've done this repair before. Its not too bad but the bumper mount, if you have to replace it, is a PITA to get off.
DennisV
post Sep 18 2024, 08:14 AM
QUOTE(friethmiller @ Sep 9 2024, 07:21 AM) *
Hmm. It appears you have the fender off in your photo. I'm guess that will be necessary if order to get access to weld the bumper mount to the frunk sidewall?
@DennisV Found out Chris was making these after having fabricated mine for a similar repair...
Did you need to remove the fender for this repair?
This is becoming a very slipper slope! Short term, I am tempted to just drill a hole and weld on another washer for the bottom mount. (IMG:style_emoticons/default/smash.gif)
friethmiller
post Sep 18 2024, 03:13 PM
QUOTE(DennisV @ Sep 18 2024, 09:14 AM) *
No, I think you can replace the bracket without removing the fender. However, I'm not convinced you need to replace it. What about just welding in the section that is rusty? I'd cut a rectangular hole out of the front cross (around this rusty area). Make it big enough to get in there to the bracket and then just cut and replace the part of the bracket that is rusted? Unless you have a hole in it going into the light bucket like I did, I'd just weld in a new section. Hell, buy the RD part and just use what you need. That would be a pretty easy repair, IMO.
friethmiller
post Sep 18 2024, 03:28 PM
Here's a pic or two of the replacement bracket from that same repair. Like I said, you don't have to replace all of the bracket just to get a bottom hole! You won't know anything until you peel back the old sealant and years of dirt.
- Lo-Fi Version Time is now: 15th January 2025 - 07:45 AM
