| Literati914 |
Aug 26 2024, 01:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,121 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I’m gonna pick one of these up and was wondering if anyone here has tried one? My only concern is the depth of the socket part itself.. could be a little short?
| windforfun |
Aug 26 2024, 01:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,065 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Scale the drawing.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
| Literati914 |
Aug 26 2024, 01:58 PM
| windforfun |
Aug 26 2024, 02:09 PM
| ClayPerrine |
Aug 26 2024, 02:13 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
If you want one, I will give you mine.
And I don't give away useful tools......... |
| Literati914 |
Aug 26 2024, 02:14 PM
I’ll get back to you when I have a real keyboard in front of me. (IMG:style_emoticons/default/lol-2.gif) Just kiddin' I'll go ahead and get one, it should be fine - I mean it is a spark plug wrench .. surely they didn't screw up the depth for an average spark plug. Was just hoping someone could tell me if they hated it, and maybe point out a better alternative. |
| Literati914 |
Aug 26 2024, 02:16 PM
If you want one, I will give you mine. And I don't give away useful tools......... Appreciate it, but no need - I'm gonna snag this one. (IMG:style_emoticons/default/beerchug.gif) |
| Geezer914 |
Aug 26 2024, 02:19 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,107 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Just use a socket and extension, you should be torquing the plugs with aluminium heads.
| Shivers |
Aug 26 2024, 02:28 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,154 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
You have to be GI Joe with the Kung Fu grip to use that to remove old plugs from a cylinder head. At least in my experience.
| worn |
Aug 26 2024, 02:39 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,501 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
I’m gonna pick one of these up and was wondering if anyone here has tried one? My only concern is the depth of the socket part itself.. could be a little short? It is sort of like the factory part. I like the factory part coupled with the supplied Allen wrench. Gets into tight spaces, and I have the racket version of the Allen wrench. |
| Literati914 |
Aug 26 2024, 02:45 PM
Just use a socket and extension, you should be torquing the plugs with aluminium heads. You have to be GI Joe with the Kung Fu grip to use that to remove old plugs from a cylinder head. At least in my experience. Good points. I like this for the simplicity of it. Easy to recognize as the spark plug wrench and easy to put your hands on quickly. "Oh there's my plug wrench" - rather than searching/fumble around with the correct ratchet, extension and socket.. That's gotten old already. This should work for at least the initial R&R.. then follow up with a torque wrench, which was always ideal anyways. Do plugs tend to stick in heads that are in regularly use? or just in ones that have been sitting in a field for several years? - LMK, I'm really not sure on that. I think I've read anti-seize on the plug threads, as a recommendation? |
| Literati914 |
Aug 26 2024, 02:50 PM
It is sort of like the factory part. I like the factory part coupled with the supplied Allen wrench. Gets into tight spaces, and I have the racket version of the Allen wrench. I'm not sure about the exact 914 supplied item, but the one I have is just a 6-7" pipe with the correct socket opening pressed on one side. There is NO rubber insert and you have to fit a screwdriver into a hole on the side to get it to turn. Again, a sloppy solution imho. Yours may be better - I have seen some that are similar to what I posted above.. Klein tools maybe, but I assumed they were 911 items. |
| 914sgofast2 |
Aug 26 2024, 03:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 775 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
That wrench looks like junk designed by someone who has never had to change a spark plug.
| Literati914 |
Aug 26 2024, 03:58 PM
| windforfun |
Aug 26 2024, 04:36 PM
That wrench looks like junk designed by someone who has never had to change a spark plug. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I don't think it's made by Snap-on. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
| Geezer914 |
Aug 26 2024, 04:45 PM
Like I said, if you are using a torque wrench to tighten your plugs, you have found the socket and the extension you need. That tool is worthless!
Aug 26 2024, 04:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,484 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Not sure that spring-a-ma-thing is going to clear the tin. Even it it does go into the tin, it looks like a nightmare trying to extract the plug without spring and/or the built in U-joint hanging up on tin and dropping plug into the tin.
Then you’ll have to go find the springy grabber thing or the magnet on the wand and play Operation to retrieve the spark plug (IMG:style_emoticons/default/headbang.gif) |
| Literati914 |
Aug 26 2024, 05:14 PM
That wrench looks like junk designed by someone who has never had to change a spark plug. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I don't think it's made by Snap-on. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Like I said, if you are using a torque wrench to tighten your plugs, you have found the socket and the extension you need. That tool is worthless! Ok, yeah I have to admit it does look a little flimsy... good thing I was lazy and didn't buy it yet (thanks for saving me the frustration (IMG:style_emoticons/default/biggrin.gif) ) I might buy the Klein version though. Those look a little more HD. I can not argue against a torque wrench but there is certainly a place for stand alone plug wrenches IMHO. |
| Literati914 |
Aug 26 2024, 05:18 PM
Not sure that spring-a-ma-thing is going to clear the tin. Now that's a good point, and it's why I mentioned the length of the socket itself in my first post. If the socket is long enough (really looks like it's not tbh) the spring wouldn't be down in the tin to get hung up. |
| Shivers |
Aug 26 2024, 06:43 PM
QUOTE Do plugs tend to stick in heads that are in regularly use? or just in ones that have been sitting in a field for several years? - LMK, I'm really not sure on that. I think I've read anti-seize on the plug threads, as a recommendation? @Literati914 They can stick, any place where water or even more so acid rain can get to the plug / head area. And yes that is what I do, permatex has an anti seize for aluminum. |
Lo-Fi Version | Time is now: 29th October 2025 - 08:11 AM |
