| dennisphelan |
Aug 20 2024, 04:14 PM
Newbie ![]() Group: Members Posts: 17 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
I have this strange problem. The front and rear turn signals work until I turn on the headlights. The front turn signals stop working, but the rear ones continue to work. Where should I look?
Dennis Phelan dennis.phelan@gmail.com |
| NARP74 |
Aug 20 2024, 04:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,582 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Stock bulbs or LED conversion?
| Dave_Darling |
Aug 22 2024, 12:50 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Check the wiring for all four turn signal buckets. Having a couple of wires switched can cause this behavior.
Search through this page for drawings of how they should be wired: https://bowlsby.net/914/Classic/TechNotebook.htm --DD |
| dennisphelan |
Sep 18 2024, 08:35 PM
Sorry for the late reply. They are LED conversions
| Spoke |
Sep 19 2024, 10:40 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,437 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Hey Dennis,
As Dave mentioned, check the wiring on the front buckets. Make sure the ground is connected to ground. The only connection between turnsignals and headlights is the dual filament front turnsignal sockets where the low intensity light is powered by headlights and the high intensity light is powered by the flasher relay. |
Lo-Fi Version | Time is now: 6th November 2026 - 09:51 PM |
