| RFoulds |
Mar 29 2024, 03:14 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 861 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
Finally installing my oil lines and the sandwich adaptor is thicker than my old one I think. Using a Derale oil filter adaptor, model no. 15702. this is making my stock Mahle filter OC28 hang down too far and the engine mount bar is in the way.
Has anyone found a shorter filter to use? |
| Geezer914 |
Mar 29 2024, 03:21 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,273 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I use K&N 2004 oil filters.
| RFoulds |
Mar 29 2024, 03:51 PM
looks like that is same size and length. Do you know which sandwich plate you have?
But I think I found the issue. When I had motor rebuilt, we replaced cracked oil filter console. the new one looks to be mounted slightly askew, just enough that the oil filter cannot hang behind the bar, or even start threading on just behind the bar. it is about 6mm too wide. So I may need to adjust the filter console a bit. |
| bdstone914 |
Mar 30 2024, 11:24 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,285 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Rfoulds
You need to look for a filter with a 3/4-16 thread size, oring close in diameter and thickness, oil pressure relief around 8-12 lbs and have the anti drainback rubber flap over the inlet holes. Fram makes crap filters but there site had good data. Once you find a workable filter most manufacturers have cross references to other brands. |
| ClayPerrine |
Apr 1 2024, 08:39 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The filter for a 1979 924 fits and is physically smaller in diameter so it won't hit the engine crossbar if used in a 914 with a oil cooler sandwich adapter.
Hope that helps. Clay |
| Geezer914 |
Apr 1 2024, 10:16 AM
I have a Mocal unit.
| Geezer914 |
Apr 1 2024, 12:58 PM
The filter for the 924 is around 5" long so it would hang below the engine bar.
| RFoulds |
Apr 3 2024, 09:37 AM
Thanks everyone. Discovered that my issue was that the engine bar is bent at the ends which is causing it lean back about. Half inch. Once I straightened it I had the clearance I needed.
| Alapone |
Apr 15 2024, 09:15 AM
Member ![]() ![]() Group: Members Posts: 110 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Thanks everyone. Discovered that my issue was that the engine bar is bent at the ends which is causing it lean back about. Half inch. Once I straightened it I had the clearance I needed. I am having the same issue with my sandwich plate and Mahle OC28 filter. The correct filter would hit the support bar. I am also having an issue with the clutch cable being in the way while installing. I have used shorter STP filters in the past but am a bit leery of quality and oil capacity. any thoughts ? |
| 914werke |
Apr 9 2026, 02:06 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,620 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
The filter for the 924 is around 5" long so it would hang below the engine bar. Revisiting this: So it is suggested that the filter for 924 is a direct replacement for say a 914 MANN / WIX filter except that is is dimensionaly longer ? How much longer? I guess I could look it up but is there a Part #? Nevermind 3/4-16 UNF MANN Part # W 719/5 @123mm long vs W 920/17 = shorter. |
| TheCabinetmaker |
Apr 9 2026, 05:49 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,375 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Lo-Fi Version | Time is now: 9th April 2026 - 11:03 PM |
