| TonyA |
Feb 4 2024, 10:10 AM
Nachmal ![]() ![]() ![]() Group: Members Posts: 695 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
Why do replacement CV joint boots have six holes instead of the four like original.
Is it so the grease has a spot to leak out in a few years and splash all over. I am getting pissed at aftermarket stuff not made right and I find this out six months after purchasing. Why are there six holes. In my quest for originality I WANT IT RIGHT (I know most don't give a crap) but I do! My rant for today thanks for watching. |
| 914Sixer |
Feb 4 2024, 10:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,480 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
The 914 boot is the same size as the stock VW Bug boot. You wound think it should be a simple program NOT to drill the 2 holes. Manufacturers don't see a market.
| mate914 |
Feb 4 2024, 10:31 AM
Matt ![]() ![]() ![]() Group: Members Posts: 940 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
Why do replacement CV joint boots have six holes instead of the four like original. Is it so the grease has a spot to leak out in a few years and splash all over. I am getting pissed at aftermarket stuff not made right and I find this out six months after purchasing. Why are there six holes. In my quest for originality I WANT IT RIGHT (I know most don't give a crap) but I do! My rant for today thanks for watching. I hear ya, but cheer up. Who else has the first LE car and was a foot model? Maybe take a pic so we can see.... of the boot, not your foot.. Matt |
| burton73 |
Feb 4 2024, 10:47 AM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
| 73-914 |
Feb 4 2024, 11:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None
A reproduction is by definition not original
| TonyA |
Feb 4 2024, 12:23 PM
Excuse me I mean original looking.
| TonyA |
Feb 4 2024, 12:25 PM
Why do replacement CV joint boots have six holes instead of the four like original. Is it so the grease has a spot to leak out in a few years and splash all over. I am getting pissed at aftermarket stuff not made right and I find this out six months after purchasing. Why are there six holes. In my quest for originality I WANT IT RIGHT (I know most don't give a crap) but I do! My rant for today thanks for watching. I hear ya, but cheer up. Who else has the first LE car and was a foot model? Maybe take a pic so we can see.... of the boot, not your foot.. Matt (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) You made me laugh buddy. |
| MartyYeoman |
Feb 4 2024, 12:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,552 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California
Add a little piece of HVAC foil sealing tape to the underside of the flange over the unwanted openings. May not look original but should stop the leak concern.
| fixer34 |
Feb 4 2024, 01:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
You got me wondering since it has been a LONG time that I did anything with CV joints, including even looking at them.
Are the 4 hole boots every 90 degrees, or every 60 (like a 6 hole), just 2 of them aren't punched/drilled out? Aren't the boots the same for a -4 and -6? The -6 uses 6 bolts I believe, so it would seem to make sense to make something that fits both. Easier to plug a hole (tape or silicon caulk) than make one. |
| 914Sixer |
Feb 4 2024, 01:12 PM
Thinking a plastic plug would accomplish closing the hole. Even a metal claw plug might work too.
| fixer34 |
Feb 4 2024, 04:39 PM
| pek771 |
Feb 4 2024, 09:14 PM
Member ![]() ![]() Group: Members Posts: 275 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None
The diameter of the boot is larger than the CV joint.. Add that to the list of concerns.
| bkrantz |
Feb 4 2024, 09:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,694 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
| jim_hoyland |
Feb 5 2024, 07:33 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,068 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
So, what is the best solution when replacing ?
| pek771 |
Feb 5 2024, 07:52 AM
I’m going to put a bead of silicone around the perimeter of the joint, and hope for the best. I think the spinning CV will shoot out some grease. Because new CV have different diameters at either end, I don’t think a gasket will help..
| DRPHIL914 |
Feb 5 2024, 07:54 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,932 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Why can't someone make a correct design reproduction??
i found a set of OEM NOS ones that i installed last year when i had to pull the transmission to do the RMS seal , so no more flinging grease around! Cant remember what world member i bought them from but i am glad i grabbed them. Phil |
| 76-914 |
Feb 5 2024, 09:07 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,882 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
These are the woes of owning a 50 year old car in a small market. Just yesterday I was complaining, to myself in the garage, about some aftermarket deviation and realized I was lucky to have something vs nothing. Those holes can be welded shut then sanded or milled. (IMG:style_emoticons/default/beerchug.gif)
| MikeK |
Feb 5 2024, 09:31 AM
Member ![]() ![]() Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Pardon my ignorance, but which six holes are you referring to? The holes for the CV bolts? Do 914's use four holes to mount?
| DRPHIL914 |
Feb 5 2024, 09:54 AM
| VaccaRabite |
Feb 5 2024, 11:50 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,864 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Because its a Beetle part that EMPI is selling to 914 owners.
Same difference with the Beetle CVs that are now appearing on 914s. Same size, same hole spacing, but for some reason the 914 part uses 2 roll pins and 4 bolts instead of 6 bolts. Zach |
Lo-Fi Version | Time is now: 13th May 2026 - 12:50 AM |
