| DBF |
Mar 3 2022, 05:17 PM
Member ![]() ![]() Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I'm bring my barn find BB back on the road and thinking of buying an ultrasonic cleaner to clean smaller parts. Anyone else using this technique and any recommendations for the home hobbyist?
My fan housing and air intakes are very grungy. I was planning to just scrub with degreaser and maybe a pressure washer, but there are a couple companies near me that offer vapor honing. Anyone try vapor honing on these parts? Thanks ![]() |
| Van B |
Mar 3 2022, 05:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
Vapor honing used to be called dustless media blasting.
It will work great for improving surface finish as you are removing material, even if it is a very small amount. But, you should degrease the part with a pressure washer first. Otherwise you’ll pay more for the guys doing the blasting. |
| Van B |
Mar 3 2022, 06:06 PM
Also, FWIW, you may consider one of these as a DIY:
https://www.amazon.com/Selkie-Pressure-Wash...t/dp/B086W4TNQC I’ll be getting one to use with fine glass beads for some ATS wheels that I’m working on. I want a raw aluminum look and a clear powder coat top lay to prevent oxidation. |
Mar 3 2022, 06:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,581 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Also, FWIW, you may consider one of these as a DIY: https://www.amazon.com/Selkie-Pressure-Wash...t/dp/B086W4TNQC I’ll be getting one to use with fine glass beads for some ATS wheels that I’m working on. I want a raw aluminum look and a clear powder coat top lay to prevent oxidation. In my opinion, this unit is near worthless. I tried one a month or so ago and give it a thumbs down |
| Van B |
Mar 3 2022, 08:16 PM
Also, FWIW, you may consider one of these as a DIY: https://www.amazon.com/Selkie-Pressure-Wash...t/dp/B086W4TNQC I’ll be getting one to use with fine glass beads for some ATS wheels that I’m working on. I want a raw aluminum look and a clear powder coat top lay to prevent oxidation. In my opinion, this unit is near worthless. I tried one a month or so ago and give it a thumbs down I just pulled that up as an example. Thank you for the heads up on that particular example though! Did you find one that worked well? |
| BillJ |
Mar 3 2022, 08:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
Highly recommend vapor honing. It does a fantatic job of getting parts very clean. I had my case and heads done on the white race car and they looked brand new.
Degrease first as suggested then get it done. Not sure how it inpacts magnesium but the aluminum was bright and shiny. |
| Mikey914 |
Mar 5 2022, 11:50 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
It's what we do. Spend the money, you'll like it.
Attached thumbnail(s) Attached image(s)
| aharder |
Mar 5 2022, 01:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,962 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region
I recently bought a Ultrasonic Cleaner when I was re-building some Webers and I'm very please with the results.
The only issue is that I should have bought one big enough to do engine cases (IMG:style_emoticons/default/headbang.gif) |
| dakotaewing |
Mar 5 2022, 01:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region
| BillJ |
Mar 5 2022, 01:51 PM
Vapor honing is very different from ultrasonic cleaning.
Basically, this is a technology that involves the blasting of abrasive material blast mixed with pressurized water. This mix is called “slurry,” and is pressurized before you hit the surface you’re treating with the pressurized water and abrasive material mix. When it’s used to clean a surface, the abrasive eliminates the materials you’re removing and the water washes them away. When it’s used to finish a surface, the abrasive smooths down the surface and the water softens it blow |
Mar 5 2022, 02:10 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,616 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
We had a large vapor blast machine at the Porsche shop where I worked. I used it on everything and it works great. It doesn’t remove base material. They aren’t cheap. Ours was $18K used. You often prep with glass bead blasting to clean the metal and prime the surface.
Talk to the vendor about prep. They will tell you what you need. We have a very large ultrasonic cleaner. It works great. All the little cheap machines are junk. Don’t waste your money. |
| sixaddict |
Mar 5 2022, 09:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,057 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Once the “blasting” is done is it necessary to coat so surface stays nice?
I’m thinking Cericote (sic) but not sure. |
Mar 5 2022, 09:27 PM
Once the “blasting” is done is it necessary to coat so surface stays nice? I’m thinking Cericote (sic) but not sure. No. It will eventually oxidize and discolor a bit like any processed aluminum. It comes out looking like tumbled or shot peened aluminum. Smooth with a dull but nice finish. It doesn’t have the matt dry look of bead blasted parts. |
Mar 5 2022, 10:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 756 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
We're a big fan of vapor blasting and powder coating. So, of course had to build a vapor blasting cabinet (as well as putting together a setup for powder coating).
Attached thumbnail(s) |
Mar 5 2022, 10:03 PM
Before photos.
Mar 5 2022, 10:05 PM
After photos.
| rgalla9146 |
Mar 6 2022, 07:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Vapor honing is very different from ultrasonic cleaning. Basically, this is a technology that involves the blasting of abrasive material blast mixed with pressurized water. This mix is called “slurry,” and is pressurized before you hit the surface you’re treating with the pressurized water and abrasive material mix. When it’s used to clean a surface, the abrasive eliminates the materials you’re removing and the water washes them away. When it’s used to finish a surface, the abrasive smooths down the surface and the water softens it blow Is there a risk in using this on an aluminum 911 engine block.....media remaining in passages and causing damage later ? What is the current best way to safely clean an engine for rebuild ? |
Mar 6 2022, 09:28 AM
Vapor honing is very different from ultrasonic cleaning. Basically, this is a technology that involves the blasting of abrasive material blast mixed with pressurized water. This mix is called “slurry,” and is pressurized before you hit the surface you’re treating with the pressurized water and abrasive material mix. When it’s used to clean a surface, the abrasive eliminates the materials you’re removing and the water washes them away. When it’s used to finish a surface, the abrasive smooths down the surface and the water softens it blow Is there a risk in using this on an aluminum 911 engine block.....media remaining in passages and causing damage later ? What is the current best way to safely clean an engine for rebuild ? Yes, the media gets gummed up in cracks and crevices. It needs to be cleaned very carefully. piston squirters pulled. The shop will steam pressure wash, ultrasonic clean, blow out passages, ect. Some people are scared about blast media in the engine but it's no different than if the engine has fine metal particles in it. I'll do it on my own build. If you can find someone with a dish washer style parts cleaner, that would be my choice. My buddy and I are looking to buy one soon. |
| BillJ |
Mar 6 2022, 09:32 AM
This is definitely inportant. On the white car when the shop cleaned the case using this process they pulled all the plugs and thoroughly cleaned all journals before resealing with anodized plugs. Really must make sure it is fully flushed.
Mar 6 2022, 10:21 AM
I started using vapor blasting a couple years ago when I restored a motorcycle. I sent away some really crusty corroded parts and got back parts that looked almost new. The owner of the Porsche shop was so impressed, he bought a machine. It’s a bit overkill. You can actually climb inside to clean it. The downside is it takes a large commercial air supply and the shop needed to buy some sort of electrical transformer. The liquid blast media comes out like a fire hose and parts only take a minute or two once they are prepped.
Lo-Fi Version | Time is now: 10th April 2026 - 11:50 PM |
