| 914werke |
Dec 14 2019, 07:38 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,543 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Here is a solution for oil starvation when driving your 914/4 in the manner it was designed!!
Highly recommended for ANY 914, street or tracked. Simple install. Available HERE & in the members vendor section (IMG:style_emoticons/default/bye1.gif) |
| CHIZ 914 |
Dec 16 2019, 11:14 AM
Member ![]() ![]() Group: Members Posts: 204 Joined: 14-May 18 From: Mountlake Terrace, Wa Member No.: 22,118 Region Association: None
Put me down for one
Thanks Rich! |
| 914werke |
Feb 14 2020, 10:59 AM
| second wind |
Apr 2 2020, 09:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
Hello there.....is it wrong thinking on my part that this will somehow get hit since it is lower that the stock set-up? I like the idea of more oil and curing the starvation of oil issue which I know nothing about. Please share a little more of why this is a good idea. Thank you very much.
gg |
| 914werke |
Apr 2 2020, 10:39 PM
Its a common concern but in reality the sump once installed is no lower than the engine mount bar. If you are dragging the sump on anything, there is something else going on ~
Its purpose it to MAINTAIN oil pressure. The 914 was designed to be capable of navigating curvy roads at high rates of speed and (with the right tires) + G-force's. The result of which is to cause the oil in the bottom of the engine to slosh away from the pickup. By extending the PU into a small oil reservoir at the lowest point of the engine, that should never occur. |
| pete-stevers |
Jun 25 2020, 08:09 PM
Shinee Side Up Prep and Paint ![]() ![]() ![]() ![]() Group: Members Posts: 2,667 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
Hey Rich I need to put an order together for you!
| drem914 |
Jun 25 2020, 09:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,067 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required?
| 914werke |
Jun 25 2020, 10:33 PM
Hey Rich I need to put an order together for you! You got my # (IMG:style_emoticons/default/smile.gif) |
| 914werke |
Jun 25 2020, 10:41 PM
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required? Typically the stock sump cover isnt an area I see a lot of leaking. (IMG:style_emoticons/default/confused24.gif) Unless of course your sump mount boss had been over torqued & isnt holding? The cap nut seal is the only other area I can see leaking, it is replaced with an tapered female bolt. No extra gaskets or special prep is necessary unless you plan on running it with the screen. (IMG:style_emoticons/default/smile.gif) |
| drem914 |
Jun 26 2020, 09:47 PM
Just put in an order. I think you had sump extension instructions posted somewhere?
| 914werke |
Jun 27 2020, 12:25 AM
Just put in an order. I think you had sump extension instructions posted somewhere? You will receive a copy with the order but I also have it posted on the downloads section on 914werke.com (IMG:style_emoticons/default/smile.gif) |
| Tdskip |
Aug 11 2020, 01:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,751 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
@914werke - Rich, are these steel or aluminum? When you go to order it shows a "Raw" as to the finish but the pictures show metal or black finish.
| 914werke |
Aug 11 2020, 02:32 PM
Rich, are these steel or aluminum? When you go to order it shows a "Raw" as to the finish but the pictures show metal or black finish. They are anodized aluminum. (IMG:style_emoticons/default/smile.gif) Initially I offered both black & raw (or Alum.) finish.. but no one wanted the black so I made that a special order option. |
| RolinkHaus |
Oct 14 2020, 05:11 AM
Member ![]() ![]() Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
I will take one too, paypal ok
| 914werke |
Oct 14 2020, 11:17 AM
| drem914 |
Apr 10 2021, 01:55 PM
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required? Typically the stock sump cover isnt an area I see a lot of leaking. (IMG:style_emoticons/default/confused24.gif) Unless of course your sump mount boss had been over torqued & isnt holding? The cap nut seal is the only other area I can see leaking, it is replaced with an tapered female bolt. No extra gaskets or special prep is necessary unless you plan on running it with the screen. (IMG:style_emoticons/default/smile.gif) @914werke Getting ready to install but had a couple questions: 1. Is there any added benefit to running the screen with the extend sump? 2. If the screen is used can I use an RTV to connect or should it be tack welded or soldered instead? |
| 914werke |
Apr 10 2021, 03:29 PM
Given that the screen will only stop rather large pieces of debris, the reality is at that point you recognize its catching stuff,
you have bigger problems to be concerned with. (IMG:style_emoticons/default/sad.gif) My belief is the screen is a hold over from the T1 design w/o a spin on filter. So no its not necessary. But.. if you want you use it, its not that hard. 1st - you need a third sealing ring to sandwich the screen flange between the sump mating surface & the cover. 2nd - you need to ream the hole in the thin alum. on the bottom of the screen that is only as large as the M6(?) sump stud, to a hole that will fit the female securing stud .. snugly. Go slow & work up to your fit. If you just hit it with a drill bit you may not like the results BTDT. Last - I also used a file & opened up the slots on the base to allow a bit more flow, no real evidence that it is necessary it just made me feel better. |
| drem914 |
Apr 11 2021, 11:56 AM
Thanks. What "sealant" should be used, as noted in your printed instructions, to connect the extender collar?
| FlacaProductions |
Apr 11 2021, 12:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,153 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Permatex Motoseal 1 or Honda/Yamabond - same stuff, I believe.
Remember - the oil sump plate is 9 ft/lbs which is 108 inch/lbs...not a pound more. This may help: http://www.914world.com/bbs2/index.php?act...t&id=716717 or this - long thread but this will get you in there: http://www.914world.com/bbs2/index.php?sho...tuna&st=100 If you search "tuna" it should yield a lot of threads. |
| 914werke |
May 17 2021, 08:44 PM
Lo-Fi Version | Time is now: 18th February 2026 - 11:07 PM |
