> Type 4 Store LE-200 Heads, Anyone Used These
Mblizzard
post Oct 9 2018, 03:21 PM
The write up sounds awesome but so is the price. Anyone have experience with these? I am building essentially a 2549. I have some good big valve heads that are ported, 44 intake valves 36 exhaust valves, dual springs, and chromoly retainers but may not flow as well as these. Not looking to build the beast of all engines but I am in so deep it is hard to stop. But $3,700 for heads is steep. Likely not as good but AA has similar heads for just over $2K. I think my current heads may leave some flow on the table but is really hard to justify the money unless someone else has an experience that makes this a requirement.
LE-200
Castings: AMC
Chambers: CNC machined 2.0 914
Chamber Step: 95.0 x 1.0mm *
Plug angle: 2.0 914
Plug size: M12
Valve sizes: 44mm x 38mm by Manley
Springs: Premium dual Crower set for 160lbs seat pressure & 330lbs at .520” valve lift.
Retainers: Crower Chromoly
Keepers: Hardened and ground for clearance
Intake Ports: Fully CNC machined with hand finished details.
Exhaust Ports: Fully CNC machined with hand finishing.
Introduced in 2004, the LE-200’s have become the benchmark for superior high-end performance Type 4 engines. So named because they represent the Leading Edge of technology and the intake ports flowed 200CFM @ .500” valve lift, a value they exceeded by the 2nd version. The exhaust ports average flow is 75-77% of the average intake port flow.
crash914
post Oct 9 2018, 05:35 PM
its a mystery to me
they are expensive, but you get what you pay for.
the springs are beastly. mine rev's up to 7K with no bounce on a high lift reduced base circle cam.
The chambers are matched to LE's pistons if you go with Nickies.
beware that these use 12mm plugs, i.e. motorcycle plugs, smaller diameter, but have a punch.
valves are special, high quality with super strong retainers.
bent one, Len sent me a new one. no head damage, guides are super strong also.
they come with matched intakes. the profile is interesting, valves are unmasked. they flow like crazy.
had these on my 103 motor, blew it up, cleaned up the heads and now they are on my 102 motor.
my head guys here were really impressed when they cleaned up the damage to the one cylinder.
Mblizzard
post Oct 9 2018, 06:11 PM
QUOTE(crash914 @ Oct 9 2018, 03:35 PM) *
Great info. This correlates exactly with the discussion I was having with Jake. Flow and quality is more important than just going bigger.
Jetsetsurfshop
post Oct 9 2018, 07:15 PM
Contact Len at Hoffman
He built me a set of heads for my race car. They were not an AMC casting.
I'd have to find the invoice but I think I paid around 2500.00 bucks and that was with all the cool stuff.
Mark Henry
post Oct 9 2018, 07:18 PM
that's what I do!
They're heads built by Len Hoffman, HAM
I'd say the best you can buy. (IMG:style_emoticons/default/beer.gif)
r_towle
post Oct 9 2018, 07:21 PM
Custom Member
Have you had your existing head checked on a flow bench?
Jetsetsurfshop
post Oct 9 2018, 07:33 PM
Len outperformed my old heads on the flow bench. I didn't think he could because my old heads have 48x38 valves. I figured the bigger cambers and valves he would have a hard time to top. Bigger isn't always better!
I'm not sure whats wrong with your old heads, but if you need a set hit up Len.
ConeDodger
post Oct 9 2018, 07:37 PM
Apex killer!
I’ve run them on two separate engines. They are the bomb! (IMG:style_emoticons/default/evilgrin.gif)
Mblizzard
post Oct 9 2018, 07:56 PM
QUOTE(r_towle @ Oct 9 2018, 05:21 PM) *
No but hard to think they would better than than these.
Bills914-4
post Oct 10 2018, 07:53 AM
QUOTE(Mblizzard @ Oct 9 2018, 05:21 PM) *
LE-200
Castings: AMC
Plug angle: 2.0 914
Plug size: M12
Here's a little discount going on,
More images for Use code FALL-10-OFF at checkout on lnengineering.com Online orders only. Offer expires on 10/11/18 at 11:59 PM One coupon per registered customer. Offer expires 10/11/2018 11:59 PM. You must be a registered and logged in to use coupons in LN Engineering Online Store. For a limited time, save up to 20% on all Nickies air-cooled cylinders and piston sets. Offer expires 10/11/2018 11:59 PM. Add 10% off coupon on already discounted store prices. You must be a registered and logged in user to use coupons in LN Engineering Online Store. Use code FALL-10-OFF at checkout on lnengineering.com Online orders only. Offer expires on 10/11/18 at 11:59 PM
Report images
Ads
Mark Henry
post Oct 10 2018, 08:51 AM
that's what I do!
QUOTE(Jetsetsurfshop @ Oct 9 2018, 09:33 PM) *
The reason is the small exhaust port, you can't put more in if you can't get it out.
T4 heads don't have much of a flow issue on the intakes, all I do is a quick clean up and blend in the seats. Time is spent on the exhaust ports.
Len has to do the CNC intake ports because of the AMC head core rework he does. I've use a couple sets of Len's heads, top notch.
Mblizzard
post Oct 10 2018, 08:53 AM
QUOTE(Mark Henry @ Oct 10 2018, 06:51 AM) *
Checked with Len but is seems that they are current out of stock on the AAP heads.
914werke
post Feb 21 2026, 03:30 PM
I revisited this thread & then looked up what the LE-200's were priced at today....
(IMG:style_emoticons/default/new_shocked.gif) (IMG:style_emoticons/default/new_shocked.gif) (IMG:style_emoticons/default/new_shocked.gif) (IMG:style_emoticons/default/new_shocked.gif)
5K !!
post Feb 21 2026, 03:56 PM
QUOTE(914werke @ Feb 21 2026, 04:30 PM) *
5K !!
Well a set of Pauter billet heads cost $18k
914werke
post Feb 21 2026, 04:24 PM
/6 vs /4 but yes 3K a chamber does sound expensive. Thats still single plug?
post Feb 21 2026, 05:12 PM
QUOTE(914werke @ Feb 21 2026, 05:24 PM) *
Dual plug 964 engine.
post Feb 21 2026, 05:49 PM
24V M64 Cylinder Head Kit Swindon Powertrain 42K
https://swindonpowertrain.com/products/24-v...inder-head-kit/
post Feb 21 2026, 06:08 PM
QUOTE(73-914 @ Feb 21 2026, 06:49 PM) *
Yea, we have a customer who asked but we are waiting on the product to be out there for a while before diving in.
914werke
post Feb 21 2026, 08:28 PM
QUOTE(73-914 @ Feb 21 2026, 03:49 PM) *
(IMG:style_emoticons/default/blink.gif) Wow thats something youd expect to be installed on a Singer. "Its a HEMI"
2mAn
post Feb 23 2026, 11:11 AM
trying to see how long I can go without a 914
Thats one piece of the kit that can build one of these...
911K by Tuthill
I price out most of their kit and it closes in on $100K before you even get started!
1 Members: Krieger
- Lo-Fi Version Time is now: 23rd February 2026 - 11:29 PM
